Starter causing a rattle at startup?
Old Nov 15, 2004 | 06:51 PM
2MuchMAX4U's Avatar
I remember reading a how to on replaceing the greese in the starter. I have a noise (well one of them) that sounds really nasty at startup. It only happens for a few seconds when starting up, more so the first startup of the day. It seems to be all the time just louder the first time of the day. I though it might be an oil problem or lack of oil at startup because the oil light stays on for a few secs at startup and because the nissan service advisor thought it might be caused by an oil filter- not nissans.
But I dunno, maybe a filter, gonna try it next oil change but I don't feel confident that it's that. I was thinking today that maybe the rattle, which sounds horrible is a issue with the starter and not the oil. What do you guys think starter? If not then what?
Robert
Old Nov 15, 2004 | 06:58 PM
Loe max's Avatar
Mine did that also, the oil light would blink for a split second during start-up. It also made a slight clacking noise during a cold start for a split second also while the oil pump did its thing. I didn't use a Nissan Filter and bought an off-brand cheapo thing so that might have been my problem. But I'm not sure if thats the sound you are talking about without a sound clip.
Old Nov 15, 2004 | 07:09 PM
2MuchMAX4U's Avatar
I know, could a filter really cause this. I've been getting my oil changed at the same place for 3+ years the noise started a while ago, I used moble 1 synthetic for most of time but have switched to castrol high mileage to try it out. Also I think the filters are a brand mighty max. I see them in a couple places in nj, not just here. I will try the filter, it sounds like clacking/rattle.
Old Nov 16, 2004 | 03:09 AM
Wasim521's Avatar
I think there may be a TSB out for this ...
http://www.infinitihelp.com/Ownershi.../NTB03-060.htm
Old Nov 16, 2004 | 06:51 AM
2MuchMAX4U's Avatar
Yeah I got a 2k1 does that still apply, and if we are technical about the rattle it's sometimes more than 1 second.
Old Nov 16, 2004 | 06:53 AM
2MuchMAX4U's Avatar
What's the best way to make a sound clip maybe that would help?
Old Nov 16, 2004 | 11:52 AM
Wasim521's Avatar
oops, I didn't take a look at your year. Not sure if that still applies.
Old Nov 16, 2004 | 01:20 PM
MaximaVQ97's Avatar
2MuchMAX4u,
Hey!! i have the same problem as you do when i start the car in the morning as im starting it the screeeeech starts to happen as the RPMS climb above 1500 RPM , the solution to this is to re-grease your starter
use the link below for more information
http://www.motorvate.ca/mvp.php/516
starter is in general area in the 5-5.5 gens
-Anthony
user 11122324
42
Jul 18, 2022 03:35 PM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
maxima297
Sep 30, 2015 03:32 PM
