How much of a performance gain is there by lowering the car?
Old Dec 4, 2004 | 12:52 AM
tfrost's Avatar
Or if any?
I'm going to install H&R springs w/ Illuminas and add 19" wheels and tires. How will the ride height differ from my now stock 2K SE?
Thanks, T
Old Dec 4, 2004 | 02:12 AM
A33 VQ30DEK's Avatar
A lot of performance gain on it. I believe getting the car lowered with struts is even better then getting just a rear sway bar, suspension wise. You better handling and also better looks also.
IMO everyone's first mod should be to drop their car.
Old Dec 4, 2004 | 02:30 AM
crispykid717's Avatar
Bigger than Jesus
Good performance gain handling wise. Lower center of gravity=better handling/cornering.
Old Dec 4, 2004 | 05:19 AM
Ammi's Avatar
350 Detroit Muscle
I felt a difference when I completed the entire suspension package; not just from lowering my car.
Old Dec 4, 2004 | 06:21 AM
GBAUER's Avatar
It adds 25 hp.
Old Dec 4, 2004 | 06:25 AM
Audtatious's Avatar
Bandwagon Lover
I know mine, after upgrading to Eibachs (still had factory shocks), was .2 sec faster than a I35, a couple other 5.5 gens and a Alty 3.5. All were stock auto's.
Old Dec 4, 2004 | 06:31 AM
SEmy2K2go's Avatar
Go BUCKS!!!
If you're going with 19" look for something in a lightweight wheel. In regards to your car having more "performance", I'd say it will perform the same, but it will handle much better, but it may launch better if you take your car to the track as it appears Audtatious can attest to.
Old Dec 4, 2004 | 07:17 AM
ghostrider17's Avatar
Originally Posted by GBAUER
It adds 25 hp.
HAHAHAHA! Agreed.....
All "performance" gains will be nominal, but the gains in handling and stability are awesome compared to stock. Unless you go to the skipad b4 & after, it'll be hard to give the improvements a value, but you WILL feel it in your ****!
Not sure if you meant gains in 0-60 times or the like, as those will be nil -but you should have very small gains in coefficient drag and braking performance due to the lowered profile of the car.
These of course will be almost impossible to detect, but you'll notice a significant improvement in the ability of the stiffer setup to resist nose-dive in heavy braking. Maybe a LITTLE better MPG on the hwy???? who knows....
Good tires will effect braking performance the most significantly behind the obvious brake component upgrades.
To me, this is STILL the best and most needed upgrade to our cars. Worth the money, and the Illuminas simply ROCK!
gr
Old Dec 4, 2004 | 09:03 AM
Audtatious's Avatar
Bandwagon Lover
That's difenately what I attributed it to (doubt it was my driving skills). After upgrading to Eibachs, the front did not seem to raise up as much upon launch. Now that I have Illumina's, the front seems to keep an even lower profile than with the factory struts installed.
Old Dec 4, 2004 | 09:11 AM
NYghettoGLE's Avatar
how much does it usually cost to drop a car?
i mean parts, labor, the whole thing.
by the way which parts are needed in order to get this done?
yeah, i'm a noob
Old Dec 4, 2004 | 09:14 AM
Audtatious's Avatar
Bandwagon Lover
Mine:
Eibachs $250
Illuminas $408
Install (shop) $300 w/alignment
$958 total
Old Dec 4, 2004 | 09:22 AM
scopium
becomes more aerodynamic.. and gains more central balance..
Old Dec 4, 2004 | 09:48 AM
turbo_gg's Avatar
Originally Posted by Audtatious
Mine:
Eibachs $250
Illuminas $408
$958 total
I got my H&R's($205) and Illumina's($408) installed for $150, and alignment was $69.95, for a grand total of $832.95
I have the setup that you are considering, 19" rims with spring/shock upgrade, and it vastly improves the "handling performance", as well as making the car look a hell of alot better. The drop is 1.4" in front, and 1.3" in back. The handling is great, and the ride is still very comfortable (compared to the stock SE suspension). You'll like this setup
Old Dec 4, 2004 | 10:13 AM
Puppetmaster's Avatar
All my parts were USED...
Progress springs: $100 shipped (6k miles on em)
Tokico HP struts: $165 shipped (10k on em)
Install by FASHIZL: $120 (but also a deal on some new Falkens, so it was less)
Yeah, I'm a bargain shopper... and proud of it...
Old Dec 4, 2004 | 10:36 AM
white m3 guy's Avatar
It adds 25 hp.
no, it is actually 10whp per every inch your lower
Old Dec 4, 2004 | 10:44 AM
schmatt's Avatar
Suspension mods are a must with the maxima.
Eibachs: ~$250
Illuminas: ~$450
Installation: $0 (Do it yourself, not hard, just takes time and an extra hand)
Also, don't forget to put in a rear sway bar. Very important for our car. I would say more important the the springs and shocks. Just remember to also use good, sticky tires. If you can't stick to the road, what good do these handling improvements do?
Old Dec 4, 2004 | 11:06 AM
Tein S tech and Modified 4th Gen KYB AGX: $220
Install Free: Do it your self like schmatt said. Its really simple for the maxima.
Old Dec 4, 2004 | 11:15 AM
NYPD-Arnold's Avatar
Z
Theoretically, it should help highway/high speed performance. You're changing the aerodynamics of the car -- so the wind resistance will be changed for the better.
Old Dec 4, 2004 | 11:33 AM
dang....too much for my blood.
any suggestions for a noob?
where can i get those used?
Old Dec 4, 2004 | 11:37 AM
I got mine all used... coulda saved myself $120 bucks if I had the time to do it all myself... see my post above.... got em all from the 5th Gen Classifieds forum....
http://forums.maxima.org/forumdisplay.php?f=60
Old Dec 4, 2004 | 01:41 PM
Ammi's Avatar
350 Detroit Muscle
Don't forget to get an alignment
Old Dec 4, 2004 | 02:16 PM
brettb's Avatar
O'rly
Maxspeed springs $90 ebay
Tokico Blues $290 ebay
Front Strut Tower Bar $15 ebay
Install free DIY
Total $395
It can be done cheaply and you might as well install the FSTB while you are at it. You will need some help with the install, I can't see anyone doing it alone. I have impact tools and that helped.
Old Dec 4, 2004 | 04:09 PM
Z
You paid nearly $300 for Blues? Holy hell did you get ripped off...
Old Dec 4, 2004 | 04:22 PM
scopium
got my Hp blues 200 bucks for the set .. 3 weeks old..
Old Dec 4, 2004 | 04:57 PM
chris'smax's Avatar
lowering the max with coilovers is the best mod you can do to the maxima besides going FI
Old Dec 4, 2004 | 08:01 PM
imported_JIC_A33
and paying a monkey to install suspension
Old Dec 4, 2004 | 10:47 PM
chris'smax's Avatar
I try to never let the grease monkeys touch my ride.
Old Dec 5, 2004 | 03:42 AM
Audtatious's Avatar
Bandwagon Lover
Some people travel or simply don't have time to DIY. I've done it before and I had rather pay someone to do work now.
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
laparka66
Aug 6, 2015 09:36 AM
