fan problem
Old Dec 4, 2004 | 03:39 PM
ticko's Avatar
fan problem
Today when i turned on my car, my aircondioning (spellling) wont turn off, i press the off button and the display turns off but the fan will still run and blow on your feet, and i can not ajust the fan speed, the fan is like stuck on blowing air in my car, can someone help thanks!
Old Dec 4, 2004 | 06:12 PM
ticko's Avatar
hmm no one
Old Dec 4, 2004 | 06:52 PM
Bluesbrekr's Avatar
Doctorate in Detailing
Does the fan keep running when you switch the air flow to the dash vents or windshield setting?
The system will blow a bit of air even with the fan in the off position. Might that be what you're feeling?
Old Dec 4, 2004 | 07:03 PM
ticko's Avatar
Yes the fan is still on no matter what i do, i press the vent and it blows it to my face, but when i press off it blows hard to my feet, its definetly the fan, it wont ajust speeds either it just stays at the highest speed.
Old Dec 4, 2004 | 08:32 PM
I30swimmer's Avatar
ok well its acctually just a venting .. air is forced into the vents right above the hood. and well it vents onto your feet. turn the tempeture to cold and turn the air off.. there will be much less air comming down on your feet.
the fan isnt acctaully on (unless you can hear it, then disregard EVERYTHING im saying) its just a pouring of air onto your feet, not really a blowing. dont worry your not losing HP, or making the alternator work
Old Dec 4, 2004 | 08:33 PM
ticko's Avatar
oh yah and it kinda smells funny and i dont know if its my imagination but i feel tired after being in there... ?
maybe its a shortage or something?
Old Dec 4, 2004 | 08:47 PM
ticko's Avatar
nope the fan is on, it wont turn off, its like stuck on!!! when i press off its on but goes to the feet, its not the vent, the fans actually on!
Old Dec 5, 2004 | 06:25 AM
njmaxseltd's Avatar
You definately have a problem with your climate control. If you have AUTO climate control, I suggest you take it back to Nissan. If you have manual climate control, try replacing the resistor pack.
Old Dec 5, 2004 | 09:30 AM
ticko's Avatar
Its auto, damn i hope its not a lot of money becuase i have to go buy all new tires too!
Old Dec 6, 2004 | 12:11 PM
ticko's Avatar
could it be a shortage u guys think, it smells funny, and when i lift my hood up and i press the circulation button the fans turn on in the engine and they kinda smell funny too.
Old Dec 6, 2004 | 03:42 PM
paralyse's Avatar
I Miss My Maxima
Pull the fuse for now -- then look into a blower motor resistor or blower motor relay, or a malfunctioning CCU (the electronic climate control unit) -- fyi, the radiator fans are supposed to come on when the A/C is switched on.
Old Dec 6, 2004 | 06:42 PM
ticko's Avatar
where is the fuse located for this one i cant find it?
it seems when i press the off button the fan is blowing towards my feet hard very hard, and that its sucking the air from the vent where ur windsheild wipers are.
Old Dec 7, 2004 | 09:59 AM
ticko's Avatar
is it ok to pull both of the "blower MTR" fuses and drive with them not there? because that seems to be the problem i pulled those fueses and it stoped blowing the air in my car! But is it ok that i pulled them out?
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
asianstyle
Sep 10, 2015 11:30 AM
