02 Simulator How to install- inside.
Old Feb 26, 2006 | 09:53 AM
  #41
steven88's Avatar
Need A Light?
I dunno if this might apply...but I heard 2k1's have longer o2 sensor wiring than 2k2-2k3s....maybe thats why you were able to reach it without problems?
Old Nov 12, 2006 | 03:45 PM
  #42
Y2KMaxGXE-R's Avatar
Originally Posted by Seelow
What sensor gives the code 430. I installed my sim on sensor with the white wire shroud. But now i think i might have hooked it up the to the wrong one. I think i should have hooked it to the red one instead. Any help fast would be awsome i want to fix it today if I could.
seelow- were you able to resolve this?
Old Nov 12, 2006 | 03:52 PM
  #43
Puppetmaster's Avatar
FYI, if you need clarification, install pics can also be found here:
http://forums.maxima.org/showthread.php?t=468152
Old Dec 26, 2006 | 02:09 PM
  #44
Pugman's Avatar
Need Help
Puppetmaster, As you can see I an a newbie to this forum. Don't have enought reply's to post yet. I would like to attach a picture to this reply but do not know how to do it. I am getting ready to do a OS sim on my 2001 Maxima and have a picture in a powerpoint doc I would like to show. Can you help me out.
Thank
Pugman
Old Dec 27, 2006 | 06:21 AM
  #45
Thank
Pugman
The picture needs to hosted somewhere like Photobucket, Cardomain, whatever, first and then you just use the VB code [img]URL[/img]. The URL should be the exact path to the pic ending in the file extension, for example:
http://i31.photobucket.com/albums/c3...x/DSC01094.jpg *
* just randomly took that from Member's Rides.
Old Dec 29, 2006 | 10:16 AM
  #46
Pugman's Avatar
Puppetmaster,
Thanks so much for your help about getting pictures posted. Here is my question. About nine months ago I was getting the P0420 code. Took it to the dealer and he re-flashed the ECM. All good until about two weeks ago the same P0420 code appeared. The SES light went out by itself two days ago. I recorded the mileage when the light went out. I will see how long before it comes back. At this point I am getting ready to install the OS2 sim. I have been reading the many posts and looking at the pictures in the forum. I am attaching a picture of my sensors. I labeled them what I believe to be correct. Could you please take a look at the picture to see if I labeled them correctly. Looking at the 4 sensors from left to right I believe the 3rd sensor is the one for the P0420 code. The 2nd sensor is for the P0430 code. See the attached picture.
http://i135.photobucket.com/albums/q...an3910/Car.jpg
Old Dec 30, 2006 | 06:27 AM
  #47
Old Dec 30, 2006 | 06:30 AM
  #48
Looks right to me.
See also:
And my O2 sim write-up is here:
Old Dec 30, 2006 | 08:06 AM
  #49
Pugman's Avatar
Thanks Puppetmaster
Old Jan 13, 2007 | 08:00 PM
  #50
drob's Avatar
code 420
Do these things really work? My 01 max has had the engine light on for 2 years. Now I need to go through inspection, and it will fail in NJ if the engine light is on. they also plug into the OBD 2 port. Is this gadget for real?
Old Jan 13, 2007 | 08:14 PM
  #51
Yes, its for real.
Old Jan 14, 2007 | 07:21 AM
  #52
this is for real, but you are the one to decide what solution will make it work. You can certainly try going the 02 sim first, because it's the least costly. I had done the same, and it worked for me for like a month, then came back on. My car was due for emissions in 2 months....and I decided to trade.
Old Jan 17, 2007 | 08:05 AM
  #53
ANorth's Avatar
So the p0420 code [bank 1], are they the secondary 02 sensors, or the primary o2 sensors? Because the way i see it (and please correct me if im wrong) if they are the primary sensors, the need to be replaced, and if they are the secondary sensors, an 02 simulator can be used to kick the SES light off.
Now, if they are the primary sensors, since there are 2, how would u know which one to replace...or both?
Old Jun 4, 2007 | 12:44 PM
  #54
MAi30t's Avatar
i30
will my O2 sensor wires on my 2000 i30t follow the same color code as the 2k-2k1 maxima?
thenewguyy
Sep 12, 2015 11:12 AM
Hailstatejig
Sep 2, 2015 06:52 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
1992maximase30
Aug 5, 2015 09:27 PM
