Anybody know at what rpm the VIAS power valve is actuated?
Old Dec 16, 2004 | 09:00 AM
Stephen Max's Avatar
I'm too lazy to search right now.
Old Dec 16, 2004 | 09:03 AM
resurrectedmax's Avatar
enthuzed.........
i'm thinking 5000
Old Dec 16, 2004 | 09:05 AM
Apparently it opens at 5200 rpm based on a dyno graph I just looked at. For some reason I thought it was a lot lower than that, like 4700 rpm.
Old Dec 16, 2004 | 09:40 AM
Loe max's Avatar
According to the people with FSM, its at 5,000rpms. But in the car, the intake tone changes at an indicated 5,200rpms.
Old Dec 16, 2004 | 10:02 AM
Progress's Avatar
It's business time.
Would you consider the change in tone as almost sounding like your ears realeasing pressure? That is what it sounds like to me.
Old Dec 16, 2004 | 10:30 AM
NmexMAX's Avatar
dot dot dot ...
Good way of putting it.
I rode in a DEK once and it seemed to open different in different gears (auto) 1st seemed later and second seemd eartelier, ~5200, but the FSM probably doesn't lie, I may have had pressure in my head.
Old Dec 16, 2004 | 03:27 PM
Matt_01SE_20th's Avatar
i thought it was 4500
Old Dec 16, 2004 | 03:48 PM
Larrio's Avatar
The Definitive AE Master
the tach sometime reads a little off from what the ECU is indicating. I've seen this multiple times using my scantool to datalog runs. Shifting at 7100 rpm on the tach only registers 6900 rpm on the scantool (which reads off the ECU), meaning the tach is slightly off. In 3rd gear, i've shifted at what looks like 7400 rpm on the tach. So given its about 200-300 rpm off, most would think it opens at 5200 rpm tach reading vs. 5000 rpm ecu reading
supposedly the 3.0 VIAS opens at 5000 and the 3.5 at 3800 rpm. However these are just estimants and it would be almost impossible to find which rpm nissan chose (i.e. 5120, 52xx etc etc)
here is a dyno graph of me and max_gator, both graphs show a 5000 rpm VIAS opening
Old Dec 16, 2004 | 03:58 PM
spirilis's Avatar
I believe the shop manual said 5200. I am submitting this as the final answer, case closed.
mvm062
Nov 30, 2020 09:00 AM
Max139617
Sep 20, 2015 07:25 PM
tardrex
Sep 11, 2015 07:35 PM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
