Installing a separate LCD for DVD's
Old Dec 19, 2004 | 07:30 PM
TriangleMan's Avatar
I have a 7.2" LCD monitor with all different mounting kits and I want to mount it just above the radio but still be removable easily.
1. Where is the best way to run a wire from the battery to the tv through the firewall and what size fuse would be appropriate?
2. What is the best way to mount an LCD assuming I don't want to drill holes in my dash if I can help it.
Post some pics of your installs too.
Old Dec 20, 2004 | 05:55 AM
nobody? geez...
Old Dec 20, 2004 | 06:25 AM
KCMC582's Avatar
you might have a better response in the audio/video/electronics forum, since there are people with the knowledge of this who post there who dont check the 5th gen forum.
Old Dec 20, 2004 | 06:46 AM
Dohcser's Avatar
Triangle LCD's usually don't consume lots of power (ampere) with that being said look at the specs on the LCD, but what I am getting at is you can put an inline fuse and tap into the Cigarette lighter. Let me know if you need more help.
Old Dec 20, 2004 | 08:32 AM
This sounds like a good idea, I have a power inverter for the dvd player/PS2/whatever so would it be good to run both the LCD and the inverter on just the cig lighter?
Old Dec 20, 2004 | 08:55 AM
Dohcser's Avatar
NO, you didn't mention an inverter. With that being said you will want to run 8 Awg wire. And if you look behind the brake pedal and down there is a spot you can drill to get out into the engine bay (Firewall). If you are worried about the LCD then you can go off of the Cigarette lighter.
Old Dec 20, 2004 | 09:48 AM
ah, so I should run the battery wire to the inverter (which it recommends for anything above 180 watt) and use the LCD on the cig lighter?
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
95naSTA
Sep 21, 2015 06:50 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
