00-01 intake manifold cleaning....
Old Dec 20, 2004 | 12:29 AM
goodhead's Avatar
hey has anyone took off and cleaned their IM? jsut curious as if there is any special steps or things to consider since its 1)plastic 2) VI
should i jsut start scrubbing? or is there a service that can clean the parts i cant get to???? thanks
Old Dec 20, 2004 | 01:31 AM
A33 VQ30DEK's Avatar
if you took it off already, i would just use brake clean.
Old Dec 20, 2004 | 04:23 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
use Seafoam is you haven't take it off.... this prout worked for me ......
Old Dec 20, 2004 | 10:01 AM
goodhead's Avatar
well im swapping it into my 4th gen to try to be more like a 5th gen, but i was worried if the brake cleaner would get back into my egine when i put it back on or not... i dunno ill figure somethign out
Old Dec 20, 2004 | 10:31 AM
spirilis's Avatar
Brake cleaner will evaporate, so I wouldn't be too worried. Besides that, I think it's acetone-based, and I know throttle body cleaner is similar, and it is OK when fed through the engine (just don't dump it in there of course...)
Old Dec 20, 2004 | 10:45 AM
GreenSeMax's Avatar
brake cleaner leaves no residue, hence you spray new rotors with it and let them dry. You'll be fine either way, brake cleaner is just cheaper than seafoam.
Old Dec 20, 2004 | 11:36 AM
5thgen2nr's Avatar
Pardon my ignorance, but WTF is seafoam? or is this in the FAQ thread....
Old Dec 20, 2004 | 12:02 PM
nailz420's Avatar
check fluids and lubricants forum
http://forums.maxima.org/showthread....light=sea+foam
for example
Old Dec 20, 2004 | 12:05 PM
Stephen Max's Avatar
I used soapy, warm water and a toilet brush and a long bottle brush I found at Ace Hardware. The toilet and bottle brushes worked great to clean out the runners and plenum.
Obviously, this was with the IM off the car.
Old Dec 20, 2004 | 06:03 PM
irish44j's Avatar
retired moderator
SEAFOAM!!!!! Seafoam is the stuff you want...they even sell it at Advance Auto these days......this stuff is no gimmick...works like a charm.
Old Dec 20, 2004 | 11:33 PM
goodhead's Avatar
stephen - i was gonna to the same thing, jsut need to go buy a toliet brush that would fit, your IM look so clean compared to mine im jealous
i like seafoam too but u cant use it for cleaning the intake manifold while its off your car, try it:
1)take your im off
2)take some seafoam put it into the runner,
3)stare at it doing nothing
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
