Noise from the ECM?
Old Dec 23, 2004 | 02:22 PM
PooRLiL'GT's Avatar
Noise from the ECM?
Car is a 2000 maxima. I just came home from driving it and after turning the car off, I hear a buzzing sound coming from the engine bay. I probe around, eventually started pulling fuses. I pulled the fuse marked 'Engine Cont 2' Which I imagine stands for engine control and the nosie went away. Could this noise be coming from the ecm? What could cause this noise? The car drives prefectly fine, accessories work, but yet, I can still here the buzzing, almost like a motor still running. I disconnected the battery in case this sort of thing would drain it.
Anyone have this problem before?
Old Dec 23, 2004 | 02:30 PM
sipock97's Avatar
I believe that noise is the engine mounts. I think there is also a tsb for it.
Old Dec 23, 2004 | 02:32 PM
SoonerFan's Avatar
Cletus
im 99% sure it is something to do with fuel...purging or something. its normal as long as it only last a few seconds
Old Dec 23, 2004 | 02:35 PM
PooRLiL'GT's Avatar
How could it be the engine mounts? I'm pretty certain this noise is electrical, with battery disconnected, noise goes away. The noise doesn't go away which is why I had to disconnect the battery while it's being garaged.
Any other ideas? Thanks for the quick replies.
Old Dec 23, 2004 | 02:39 PM
sipock97's Avatar
In the 01-010 FEB 01 Engine Mount - Buzzing Noise After Engine Shutoff tsb thread there is an entry from alldata. I havent done any research but remebered reading about it.
SoonerFan's Avatar
Cletus
GLEs actually have electrical motor mounts...but i dont think thats what it is
Old Dec 23, 2004 | 02:42 PM
PooRLiL'GT's Avatar
That's interesting, I check out that TSB, thanks!
What else could it possibly be?
SoonerFan's Avatar
Cletus
i stand corrected...its the motor mounts...here is the TSB
http://maxima.theowensfamily.com/tsb/NTB01-010.pdf
Old Dec 23, 2004 | 02:55 PM
PooRLiL'GT's Avatar
Thanks for the link. But it states, vehicle exhibts a buzzing noise for several seconds. On my 2000, the buzzing won't go away at all, even with key off, engine off. Does anyone know what that fuse is protecting? Are the mounts connected to fuse ' Engine Cont 2 '?
Old Dec 23, 2004 | 02:58 PM
sipock97's Avatar
Not sure...I have heard mine do it for a few seconds and then stop. and that was with the engine off and key out...
Old Dec 23, 2004 | 03:04 PM
SoonerFan's Avatar
Cletus
the engine control unit (ECU) controls the motor mounts (along with hundreds of other things). so removing that fuse turns off the ECU which stops sending the signal.
Old Dec 23, 2004 | 03:05 PM
PooRLiL'GT's Avatar
Even with key out it stays on, lol. I was probing with a stethoscope, but couldn't hear a damn thing that sounds like the buzzing. Just ear, it does sound like it's coming from around the mounts or something else towards the bottom of the engine. If it is the mounts, I hope tha's all it will be. Don't wanna have to replace the pcm.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
