Does anyone have 245/40/R18 on thier 5th Gen?
I know this is a tire question but its about my 5th gen so i will post here too.
Does anyone have or put 245/40/18 tires on their 5th gen Max.
Not sure if they will rub when i turn my wheel or any other problems.
Let me know any info.
thanks
thanks
What offset and wheel size will you be running with this tire size? I am running this tire size with a 18x8.5 wheel and +39 offset front and +34 offset for the back without any rubbing. if you run too low of an offset, they might rub.
My 255-40-17s only rub when you turn the wheel all the way IN- it rubs on the splash shields, I run 38mm offset wheels. I had 245-40-18 Potenza SO3s on 42mm offset wheels and it rubbed in the same spot, even worse than the 17s do. Its all bout the wheels.
I have 18" 350z wheels with the factory 245 bridgestones. Eibach springs and iluminas, The passanger rear only rubs over bigs bumps with a fat bastard in the passanger seat. I need to grind down the body seam in the wheel well to correct this.
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 23, 2015 03:38 PM
Violator
Sep 9, 2015 10:14 AM
