89/93 octane vs VQ35 DYNO
Just thought I would share this with our VQ35 brethren. I drive a 3.5SE 5MT Altima and due to the high gas prices we had, I started using 89. Now that the gas prices are down I started using 93 again. Of course the computer adjust for 89, but alas it doesn't adjust back up for 93 (had to disconnect the battery to reset the ECU).
89 (run 1) vs 93 (run 3)
That is interesting. Are you sure you gave your computer enough time to adjust for the 93 octane? Maybe it just takes longer to adjust back up? I accidentally put 87 octane in my wife's car last week (I run 87 octane in my daily driver Explorer and had my head up my *** that day). I realized what I had done and have put about a tank and a half of 93 octane in since then.
I'm going to be dynoing the Max on Friday, but the battery will get disconnected for the CAI install, so I won't be able to confirm or deny your theory.
The ECU will retard timing to the point that detonation is no longer occurring (when using a lower grade of fuel). It's good that someone finally posted a dyno about this as there have always been many false rumors flying around (about the effects of a lower fuel grade in an engine that requires premium).
I find it hard to believe that 6-7% is gained/lost using 89. Isn't the min suggested like 91? I assume the pulls were on different days and thus conditions could have been different (yeah it shows SAE though). Thanks for posting
Could you give a little more detail as to the methodology of your dyno runs? What happened to run 2? What octane was used for run 2? Did you buy 3 successive runs and switch gas and reset the ECU at some point? I would guess by what you wrote that you used 93 octane on the second run but did not reset the ECU and did not see much of a difference in power right?
Any chance you can do a dyno run with some Sunoco Ultra 94??
I think it was Road and Track that DYnoed a few high perf cars a few years ago to show the power loss of using lower octane fuel in cars whose computers (like the MAximas) can adjust the timing. If I recall corectly the BMW 540 power loss was like 20 hp dropping from 93 to 87 Octane. So I can believe a 10-15 hp diff in the MAxima. Makes sense. Problem is people don;t realize that many cars computers dont adjust timing and they get better hp from a lower octane fuel.
I am a little surprised that there is such a big difference, but not surprised there is a difference. Nissan obviously didn't just want you to spend more money on fuel. If Nissan was based in the Middle East wouldn't that be sketchy
Mark
Mark
Somewhere around the 93ish octane point N/A cars see diminishing returns on better fuel. Unless they have reprogrammed ECU's which can make some use of higher octanes. I thought I30tMikeD ran at the track and showed no gains a year ago with like 95/96 blend.
http://forums.maxima.org/showthread.php?t=357948
http://forums.maxima.org/showpost.ph...65&postcount=8
Curious what the best way to dyno compare would be. Pull on empty 93 octane, go fill with 95, drive around 30-50miles, and pull again with similar dyno conditions that same day?
After 93 octane your not going to see much performance gain. The engine was designed around 91 octane. 91+ octane does not produce more power. Theoretically 87 produces more power, but only if the engine was designed to use it. Like mentioned previously, I'm sure Nissan knew that 93 octane wasn't going to be a strong selling point.
JoshG
51
09-21-2015 10:41 PM
sdotcarter
09-02-2015 09:53 PM
MaximaDrvr
08-19-2015 08:20 PM
