Corners, fogs, interior lights died after indiglo
I installed new gauge faces and tried to wire them to the dimmer switch. Now my corners, fog lights, and interior illumination(buttons 'n sh*t, guages' needles) dont work, and neither does the dimmer switch. But get this, everything starts working when I remote start the car! As soon as I take it off the remote start, all those lights turn off again. Voltmeter shows no current going to the dimmer switch when off the remote start. "METER" fuse is good.
Can anyone recommend what or where I should check for problems? What could it be?
Originally Posted by scopium
did u connect the indiglow to the "dimmer" or the "dimmer light"
also check you fuses.. maybe you blew a fuse.
Originally Posted by BustaReims
You blew a fuse. It is a 10A fuse in located in the box under the hood...it is the fuse that is marked as REAR LIGHTS
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
