something bangs under my car...
Old Jan 3, 2005 | 07:25 AM
nailz420's Avatar
I am getting bangs under my car on bumps usually at speeds over 40mph, but sometimes at lower speeds also. It started happening after I installed Warpseed Y-pipe and had my Progress RSB adjusted by a mechanic. I've read that the RSB can bang, but I also saw a few posts that Y-pipe can bang also. How can I tell the difference between the bangs? What's more likely?
Old Jan 3, 2005 | 09:05 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
both are likely. but the y pipe bang is typically heard on accleration since the exhaust is pushing down. the rsb bang is heard going over bumps. you can eliminate the y pipe bang by removing the black cross member under the y pipe. you can eliminate the rsb by loosening the bolts on the bushing and moving them further in or out. without knowing its location right now, i could not tell which way to adjust the rsb bushing.
Old Jan 3, 2005 | 01:48 PM
NisMo-Max's Avatar
My rear sway bar used to bang, i just had to readjust it, but im sure thats ur problem, if its happening over bumps....
Old Jan 3, 2005 | 02:26 PM
scopium
make sure your sway bar is DIRECTLY under the rear beam .. if its just bit further back.. it will bang
Old Jan 3, 2005 | 09:49 PM
nailz420's Avatar
Its under the beam alright, but my mechanic decided to help me and moved the brackets all the way to the welds. Before they were about 1 inch away from the welds. I looked for some info on the site and found that the brackets should be about 4.5 inches from the "curve", whatever that is. So I had them moved 4.5 inches from the welds. It still bangs.
Old Jan 4, 2005 | 12:59 AM
NisMo-Max's Avatar
make sure the rear sway bar sits before the rear beam meaning towards the front of the car....
Old Jan 4, 2005 | 06:49 AM
nailz420's Avatar
HuH???????
Old Jan 4, 2005 | 08:56 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Check and see if you didn't ran over a dog or cat...
Lakersallday24
Jun 16, 2019 01:35 AM
Quickgtp
Aug 27, 2015 02:13 PM
2k0to2k3
Aug 18, 2015 09:59 AM
MikesChevelle
Aug 9, 2015 11:50 AM
