Blown MAF
Old Jan 3, 2005 | 09:36 PM
PeteusMaximus's Avatar
Blown MAF
when it goes what part is "blown"? does a metal piece inside break? Has anyone taken it apart?
Old Jan 4, 2005 | 11:09 AM
hakimis's Avatar
The actual sensor in it! The maf is really easy to change. Litterally 5 seconds. It's only 2 screws.
Old Jan 4, 2005 | 11:49 AM
2002 Maxima SE's Avatar
It will leave a hole in your hood when it blows.
Old Jan 4, 2005 | 12:02 PM
Jime's Avatar
Its the electronic component that fails, its not visible to the naked eye, its like looking at a computer chip, can't tell if it works or not just by looking.
Also you can't change it in 5 secs Hakimis unless you are really fast it takes me over 15 secs. lol
Old Jan 5, 2005 | 10:22 AM
hakimis's Avatar
Aren't you cute! You know what I meant; it's very easy to change. I'm a girl and I did it with no problem.
Old Jan 5, 2005 | 10:28 AM
Sammzway's Avatar
Shouldn't you reset your ECU if you install a new MAF or that's not necessary?
Old Jan 6, 2005 | 06:39 AM
hakimis's Avatar
Yeah, before you do it take off the negative terminal, change it (the MAF) and wait about a minute and then replace it.
Old Jan 6, 2005 | 09:43 AM
silvermax2k2's Avatar
i've never unplugged my batt before/after installing mafs/intake..
Old Jan 6, 2005 | 08:40 PM
super6's Avatar
i thought you are supposed to change the whole peice when chaning the maf, and not take it out of the housing???
Old Jan 6, 2005 | 11:46 PM
crispykid717's Avatar
Bigger than Jesus
Good b/c it wouldn't do any good for a 2k2. Only works on 2k's and 2k1's.
Old Jan 7, 2005 | 01:36 PM
hakimis's Avatar
I changed the part that only has 2 screws holding it in and mine is fine.
Old Jan 7, 2005 | 01:59 PM
JClaw's Avatar
On the altima forums I read that 2002-2003 are plagued with bad MAFs. Nissan seems to have fixed the problem for 2004 and 2005. Someone actually installed a 2004 MAF on a 2002 and he says all the difference is a rough/low idle. Anyone try this? I have to buy a MAF but I don't want to get a '02-'03 POS (I have to run it on 2002 ECU).
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
homewrecker
Sep 24, 2015 07:01 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
ballerchris510
Sep 10, 2015 09:35 PM
