injen intake help
Old Jan 5, 2005 | 03:04 PM
pimpinmax's Avatar
injen intake help
hey guys well this is my second post i just got a 2002 maxima and i installed the injen cold air intake but i want to add the aem bypass valve anyone do this yet? i just tried but it doesnt fit i need to cut the pipe shorter to make it fit. any info would be helpful
Old Jan 5, 2005 | 03:47 PM
jerome johnson's Avatar
Yup, you will have to cut like 1" off the pipe to make it work, but I had heard from old posts that you will lose horse power with the AEM bypass valve installed.
Old Jan 5, 2005 | 04:07 PM
03tgtmaxima's Avatar
it kinda restricts the air flow like if you put a rag or yout tee shirt over your mouth and blow through it but i know that especially here in san fran where it can get wet fast i would rather loose a couple horse power and save the engine if a puddle would happen to jump out of no wheres
Old Jan 5, 2005 | 09:37 PM
2k2kev's Avatar
It's chrome alright...
Why install a bypass? Why not just never drive through standing water instead??
Old Jan 5, 2005 | 09:41 PM
joebangaa's Avatar
^^ haven't you ever been in situations where you're on a busy road that happens to have a flooded part and there isn't anywhere really to stop or pull over or turn around? couple days ago i was on a one way road that a lot of people take with no shoulder, an area was flooded, had to go right through it unless you're gonna stop up traffic
Old Jan 5, 2005 | 09:43 PM
KLOOGY's Avatar
L33t BMW Drivah
Your mistake was getting an Injen to begin with. Living in Irvine, this shouldn't be an everyday occurence for you.
Old Jan 5, 2005 | 09:49 PM
ChromeSE5's Avatar
i really dont think the injen falls that short. I drove my intake in deep water (filter is level with tranny and im lowered) and i didnt hydrolock luckily
Old Jan 5, 2005 | 10:00 PM
nyautostyle's Avatar
i havent had a problem with my injen set up.. its been raining everyday here too. why would u install the bypass? i dont understand
Old Jan 6, 2005 | 04:32 AM
2k2kev's Avatar
So if there was 2' of water you'd go through?
I wouldn't do that with a stock setup, much less with an injen. One way road or not, if it was flooded I'm turning around.
Old Jan 6, 2005 | 06:43 AM
kcowden's Avatar
With the position of the Injen intake you'd have water coming in your doors before you'd start sucking water in through the intake. Injen isn't bad... looks cool but WAY overpriced IMO.
Old Jan 6, 2005 | 08:28 AM
alicious's Avatar
the org...not what it was
Although I have a Place Racing CAI it works the same as the Injen in the sense of it being a CAI, I did put on a bypass valve at least for right now and probably thru the spring because of where my CAI is located (about five inches from the tire) and is pretty much exposed to the elements and I didn't want to take any chances until the weather gets better, plus it only took me 20min to put it on so taking it off will be a snap. It DOES kill hp and sound SLIGHTLY, or at least it does on the PR CAI.
I had to cut the pipe before I put on the bypass valve so it didn't make a difference. If your worried about moisture (especially living in MA) and you want to be on the safe side, put it in, it'll drop your power slightly but not by much.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
