Blower makes weird noise.. :(
Old Jan 6, 2005 | 08:47 AM
Sammzway's Avatar
Lately i've noticed that when I have my heat on low, the blower makes like a weird noise as if some kind of wire is like preventing it from spinning properly. But when its on high or med. I don't hear it. Weirdddddd.. anyone had this problem? Is there a recall on this kinda thing? Maybe the blower is about to give up on me?
Old Jan 6, 2005 | 08:49 AM
ghostrider17's Avatar
In-cabin filter
Try cleaning-out the in-cabin air filter/ port.
I get all sorts of crud in there in mine, and it consistently gets caught in the blower and makes odd noises.
Other than that - you're screwed!
gr
Old Jan 6, 2005 | 08:51 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
gr
Yes just clean it.... or replace the spinning wheel inside the blower.. they did that to my car.. a long time ago......
Old Jan 6, 2005 | 09:07 AM
Sammzway's Avatar
Ah the incabin filter... alright let me search the how tos on that. Can I find the filter at autozone or do I have to run to the dealer?
Old Jan 6, 2005 | 09:13 AM
Don't know for sure about autzone....but doubtful.
Stealer will get you for $50 + for the dual element carbon activated model.
It was a bite, but with the pollen and pollution here in the ATL, I found it worthwhile. Breathing fresh air in stop and go traffic is important to me and my sensitive nose.
I got screwed by Nissan when I bought the car -- they had some cheapo paper version in there that wasn't worth a ****e!
It got tossed quickly.
The box is a little bit tricky to access behind the glovebox - make SURE you don't disconnect the SRS plug when you do it....bad-bad-bad.
Directions are in the sticky HOW TO's somewhere, in .pdf.
gr
Old Jan 6, 2005 | 09:27 AM
BM_00's Avatar
I assume it's the same 'ticking' noise I had when I turned on the blower control button. Basically it's the motor behind that's at fault. No recall but there's a TSB(Blower Motor Noise) for this which describes to replace the motor($).
The dealer(OEM) to save money might not replace the motor assy but use insulation to reduce the noise. That happened to me. This occured within my warranty(2 years ago) and I went to the dealership to get it fixed. Instead, they placed insulation to reduce the noise. I demanded that they replace the motor assy but they said the motor is not completely defective. My blower motor still functions good.
I guess you're out of warranty. Maybe you can fix this yourself with some insulation. I would.
Old Jan 6, 2005 | 09:31 AM
Sammzway's Avatar
Originally Posted by BM_00
I assume it's the same 'ticking' noise I had when I turned on the blower control button. Basically it's the motor behind that's at fault. There's a TSB(Blower Motor Noise) for this which describes to replace the motor($).
This occured within my warranty(2 years ago) and I went to the dealership to get it fixed. Instead, they placed insulation to reduce the noise which it did but you can just barely hear it. I demanded that they replace the motor assy but they said the motor is not completely defective.
I'm not covered under warranty so what should I do? Can I show them the TSB and get it covered ? Or I gotta pay?
Old Jan 6, 2005 | 09:37 AM
I didn't know about this TSB.
Old Jan 6, 2005 | 09:39 AM
BM_00's Avatar
Bro, you will certaintly pay. The TSB will not cover you since you're out of warrranty. If you want ask the dealer for a quotation on the work or go to a local mechanic you trust or find info to do this yourself.
Old Jan 6, 2005 | 10:08 AM
Sammzway's Avatar
Yeah, i'm probably just going to order the blower from the dealership and get my mech. friend to put it in. thanks alot for quick help , but should I bother changing my in cabin filter? I can't find the how-to on that.
Old Jan 6, 2005 | 02:47 PM
GBAUER's Avatar
DON'T ORDER FROM THE DEALERSHIP. I had the same problem. Shop your local friendly neighborhood junk yards and you should be able to find one. It'll save you about 3 bills.
Old Jan 6, 2005 | 02:49 PM
SoonerFan's Avatar
Cletus
i have the same problem but it doesnt do it very often and i dont even notice it anymore
Old Jan 6, 2005 | 03:15 PM
BM_00's Avatar
In my opinion, if it's your blower that's causing this "noise", don't waste your money on a new blower motor especially from the dealer. Like I said mine wasn't replaced, it works good and I can barely here the ticking noise even after 2 years. Ask your mechanic friend to install some insulation.
If your blower did fail completely then that's another story where you'd get a new one, equivalent or used from junk yard.
For basic "how-to", read and check your owners manual for your cabin filter. Replace it when it's required as per the instructions.
Old Jan 6, 2005 | 03:21 PM
BM_00's Avatar
Since you got an '02 max, I think it be a very good idea to find and file all of the TSB's for that year and use them as reference in case something fails within your warranty.
Old Jan 6, 2005 | 03:22 PM
GBAUER's Avatar
Mine started making noise at 70k. by 85k, it was unbearable. Just spend the 65 bucks at a junkyard and get it over with. By the time you pay a mechanic to put a bandaid on it, you'll end up spending the same amount and it will still be wrong.
Old Jan 6, 2005 | 05:08 PM
Sammzway's Avatar
I'll give junkyard a shot and see what I can find. I'm gonna go look thru the owners manual and figure out how to clean/change the filter (hopefully that'll fix the noise). I would insulate it but like GBAUER said, it's better to just replace part and fix the problem rather then putting a temporary solution to it. Thanks a lot fellas.
By the way, for those of you who want to change the cabin filter, I found a site that sells them, you can order from here..
http://www.courtesyparts.com/Merchan...de=B7200-00005
Old Jan 6, 2005 | 05:20 PM
Sammzway's Avatar
For those of you that are having the same problem as me, here's Housecor's how-to change in-cabin filter.
Old Jan 7, 2005 | 10:42 AM
03blk6mt's Avatar
I had a problem with the blower motor on my 03, only it makes a ton of noise when it's on high. Dealer replaced under warranty...you might not be so lucky as you're prob out of warranty. But it definately made a similar noise...almost like there was something stuck in there.
Old Jan 7, 2005 | 10:52 AM
greekmax2k1's Avatar
the best solution.......get a new car
Old Jan 7, 2005 | 11:12 AM
GreenSeMax's Avatar
haha yeah get a new car with more problems to deal with, my blower does the same thing, but not all the time. Particularly when it's very cold when i first start it, then it quiets. Sometimes it's intermittent during a trip. I have just gotten used to it. Plus my Bose still works, so i'm all set.
Old Jan 7, 2005 | 11:16 AM
GBAUER's Avatar
I took mine apart and found out it was the bearings. POS's! They didn't last very long.
Old Jan 7, 2005 | 11:24 AM
GreenSeMax's Avatar
it doesn't surprise me, what did you pay for it? or did you not replace?
Old Jan 7, 2005 | 11:40 AM
Sammzway's Avatar
God damn it, a new blower costs about 800 bucks. Although my car did not come with a in-cabin filter, but i've ordered one thru courtesy nissan for 50 bux. I guess i'll use this until it completely breaks down... like they say, if it aint broke don't fix it. lol
AaronL
Nov 15, 2020 11:52 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Smackasmith
Feb 1, 2016 12:40 AM
bennuss
Sep 11, 2015 05:55 AM
pktaske
Sep 4, 2015 08:40 AM
