whoaa whats the deal
Old Jan 6, 2005 | 05:54 PM
I30swimmer's Avatar
alright so i got my brake pads changed about 5000 miles ago. and have noted that my rear brakes are dusting about tripple what my front ones are.
before i got them changed at least i think the front ones were about twice as dusty as the rear.. why the change? will this stop?
Old Jan 6, 2005 | 08:18 PM
MaximaPolak's Avatar
Mine are doing the same thing on my 03 maxima.....
The rear, since i put on new rotors and OEM pads, has been dusting way more than the front. I would also like to know what the reason for that is.
Old Jan 7, 2005 | 07:39 AM
PTNR's Avatar
this is the same for me. i got the rears replace by nissan more than 6 months ago and ever since then they dusted far more than the fronts. i thought this may just be a change in the rear pad material but who knows. i had fronts done just recently by nissan and still the rears dust more than the fronts. i would like to know why as well.
Old Jan 7, 2005 | 03:33 PM
026speedmax's Avatar
i had the same problem and was told that the organic compound was changed on the brake pad surface, causing it dust a lot more
Old Jan 7, 2005 | 04:25 PM
BLKMAX005SPD's Avatar
maybe your caliper is frozen?
Old Jan 7, 2005 | 08:49 PM
I30swimmer's Avatar
i live in florida.. so prob not
Old Jan 7, 2005 | 09:59 PM
um...cold weather doesn't have anything to do with frozen caliper's
it can happen in any weather...
Old Jan 8, 2005 | 12:08 PM
Zero Deuce SE's Avatar
That makes the most sense. That's why some people switch to ceramic pads. They don't dust like other compounds do.
Old Jan 8, 2005 | 12:50 PM
GBAUER's Avatar
I use ceramics, but if I were in your situation the first thing I would do is bleed the lines. Might be air entrapment.
Old Jan 8, 2005 | 01:07 PM
How much dust do you get with your ceramics. Air in the brake lines would make a soft peddle and bad braking not dusting.
Old Jan 9, 2005 | 08:49 AM
claudiusmaximas's Avatar
i would switch to diff pads.
Old Jan 9, 2005 | 09:49 AM
I30swimmer's Avatar
how would you bleed the lines? i dont have a lift or jack stands so how would i go about doing that.. cause the pedel is a little softer than i would like it. but the car will still stop pretty well
Old Jan 10, 2005 | 09:39 AM
PTNR's Avatar
who told you this? cause i had fronts replaced more recently than the rears and the rears still dust more. is this change just for the compound on the rears? doesn't seem likely.
Old Jan 11, 2005 | 01:22 PM
PTNR's Avatar
bump for more info
James92SE
142
Jan 2, 2024 09:23 AM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
mpbclutch33
Sep 21, 2015 01:54 PM
