P1320??
Old Jan 10, 2005 | 07:24 AM
dentonmax00's Avatar
P1320??
My Max is throwing this code. Does anyone know what it is and how much it will cost me? AutoZone didn't know what exactly the code was but said it was an "ignition system or misfire problem". Coil was the first thing that came to mind but the car drives fine, no hesitations. I am really tired of the SES light, this is the 3rd time in a year.
Old Jan 10, 2005 | 07:56 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
If I had to wager a guess I would suspect the ignition coils.
Old Jan 10, 2005 | 09:43 AM
MrPoisse's Avatar
its gonna get worst and worst, and eventually, youll notice the misfires.
you will soon have to replace some, if not all your coils.
I PM'ed you about my experience. check out your inbox!
Old Jan 10, 2005 | 10:29 AM
Max_Vader_2K's Avatar
I was getting by with my ignition coil problem with a misfire about 1 every 2 months. Now the misfires are about 1 or 2 per month. I will have mine replace as soon as I can afford it. Hopefully it wont be too late.
Old Jan 10, 2005 | 08:12 PM
BM_00's Avatar
P1320=Primary ignition fault. One or more of your coils are intermittently failing. If you pull a second code (eg.P0030), that means the specific cylinder is misfiring. You can replace them yourself.
-Check also your ground cables(2 of them above oil cap towards passenger side) and battery cables are tightly secured.
I got this condition 2x, 2 months ago but never since. I did buy the coils to replace them eventually.
There's a big history with this infamous code. check out the Igntion coil thread which is down a few pages. Good luck
Old Jan 12, 2005 | 12:42 AM
FusionAcid's Avatar
almost positive its the ignition coils.
i had a p1320 code thrown too. changed all 6 coils for $250 shipped. haven't had an error-SES thrown for 1 yr.
Old Jan 13, 2005 | 03:22 PM
pathfound1's Avatar
i had that code come up and i had it checked and it said it was the ignition sensor but i left for 2 weeks or so and it just turned off by itself...but then about a month almost later my SES light came back on..
Old Jan 15, 2005 | 08:25 AM
kiski's Avatar
Code #P1320 is definitely an ignition coil problem. The AutoZone computer should be able to tell you EXACTLY which coil or coils are bad. The front coils; #2, #4, & #6 are a piece of cake to replace...the rears are another story. I had a bad #2 ignition coil and only replaced it 12,000 miles ago and so far, knock on wood, all 6 coils are running fine.
msellas
Sep 23, 2015 09:16 PM
sake1bs
Sep 19, 2015 09:32 PM
Hedge
Feb 7, 2005 01:11 PM
panda_1
Mar 27, 2004 12:59 PM
