2000 Big Problem?
Old Jan 13, 2005 | 05:59 PM
DerekB's Avatar
2000 Big Problem?
My service engine soon light is on. The erg flow is screwed up. The dealer ship showed me the hose right past the throttle body is glogged. So me and a buddy sprayed some solvent and cleaned it out the best we could. My light went off for about 5 minutes. I reset the codes by diconnecting the negitive on the battery. Now the light is back on and my car run like sh*t. Does not idle good. And does not have hardly any power. HELP PLEASE.
Old Jan 13, 2005 | 06:03 PM
Klutch's Avatar
Sea Foam!!
Old Jan 13, 2005 | 06:13 PM
DerekB's Avatar
Sea Foam??
Old Jan 13, 2005 | 06:15 PM
Klutch's Avatar
Originally Posted by DerekB
Sea Foam??
Yup. Browse around, you'll hear all sort of stuff about it. If you could search you'd find it easily. Since you aren't a paying member you have to manually browse around.
doublea's Avatar
If the idle doesn't come back to normal then your IAC switch might be screwed.
AA
Old Jan 13, 2005 | 06:20 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Don't use any crapy solvent... Use the Sea Foam. Go to autozone or Advance auto parts.. the can is $3.88, use the Brake booster vacumn line and use 1/3 of the can or maybe more depending on how clogged is the line. Your car is going to smoke like hell... don't worry about it... do this and CHANGE THE OIL AFTER IT, this should help your problem........ The SES get used to it.. maybe code P420 or something like that...
Old Jan 13, 2005 | 06:35 PM
DerekB's Avatar
The code is 0400 egr flow malfunction. I know where the hose is its hard to get to being just past the throttle body and all. I guess I can take it apart to get to the hose. But if I can't get to this job in the next week or so. Is my car going to start running right. It ran fine until I put the solvent in and reset the codes. The car has started to idle fine just when I get to 2500+ rpms.
Old Jan 13, 2005 | 06:37 PM
DerekB's Avatar
Also explain using the brake booster line please.
Old Jan 13, 2005 | 07:16 PM
DerekB's Avatar
Anyone....
Old Jan 13, 2005 | 07:37 PM
mhadford's Avatar
Brake booster line is a vacuum line that goes from intake manifold to brake booster. If you disconnect it from brake booster, it will suck seafoam into line and into intake manifold. I have no opinion on whether this is a good idea - I've never done it.
I think you should go to your local autoparts store and buy the Haynes manual for your car, as well as spending a few bux to join this forum so you can search. The combination will save you hundreds (at least) on your car ownership costs.
Best wishes!
Old Jan 14, 2005 | 04:24 PM
paralyse's Avatar
I Miss My Maxima
Wanted to add one thing to this post. When you drive your car around with a vacuum line, PCV, EGR or whatever that is broken or clogged up, the computer's adaptive memory "learns" to compensate for the reduced air flow and remaps the air/fuel tables. This keeps your car running. However, when you fix the underlying cause, the computer will need awhile to "relearn" air flow, etc.
Seafoam is good, btw. Once you clean out your engine, let it run for awhile at varying RPMs so that the ECU will relearn the proper programming.
Old Jan 14, 2005 | 04:28 PM
E55AMG2's Avatar
Wat
ECU reset is necessary to re-learn BTW
Old Jan 14, 2005 | 06:42 PM
Lontar1's Avatar
the Haynes manual SUCK... I'm still looking for a good one.....
Anuhow.. try the seafoam.......
Old Jan 14, 2005 | 10:25 PM
E55AMG2's Avatar
Wat
search, there are threads asking ppl who has the 2k-2k1 Factory ESM....most ppl are nice enough to give it to u for free too
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
ef9
Sep 10, 2015 10:35 PM
