Both foglights cracked again
Old Jan 14, 2005 | 08:11 AM
Burton's Avatar
Nissan makes some ****ty foglights as mine have cracked again in the cold.I am done with buying replacements unless someone makes a cheaper but better one for the 2003 max.
Old Jan 14, 2005 | 08:23 AM
LA02MAX's Avatar
there are some generic ones on ebay, but im sure theyre just the same...i havent heard of them cracking from the cold before, there must have been something that hit them, and since they were so cold, they were fragile...what i suggest you doing is getting lamin-x or something similar to put over them. The fogs on my car were cracked when i got it, and since then, i bought new ones and put lamin-x on them and so far, no problems...although it doesnt get NEARLY as cold as it does where you live there, it gets below freezing and still no problems..
Old Jan 14, 2005 | 08:29 AM
DonVince's Avatar
After three sets of fogs I stopped changing them. The ones I have in there now have been cracked for almost 6 months.
Vince
Old Jan 14, 2005 | 08:58 AM
Burton's Avatar
well there is a design problem forsure as I heard many stories of them cracking . Nothing hit them at all ,they cracked sitting in the driveway. There has to be something nissan will do to look at this ****ing problem.
Old Jan 14, 2005 | 09:31 AM
bladerunr's Avatar
It must be a new problem because I have not heard that before. How cold has it gotten up there? I know for the rock issue some of us have tried the 3M clear plastic coating to protect the glass. I don't know if that will help but it's a cheap enough mod that can't hurt.
Old Jan 14, 2005 | 10:40 AM
F23A4's Avatar
Vince
Ouch, 3 sets???? After the 2nd set, I would've picked up some GXE blank inserts and not bother any more.
So far, I only have a 'rock-hit' crack in one lense. But, it's barely visible from >5ft, so I'll live with it for now.
Old Jan 14, 2005 | 02:52 PM
MaximaPolak's Avatar
NEVER CRACKED....use smaller wattage bulbs...or HIDs
Old Jan 14, 2005 | 03:02 PM
Gsilk's Avatar
Reported
nissan made the 2k2's/2k3's with glass lenses. thankfully 2k's have plastic covering and mine have yet to break.
Old Jan 14, 2005 | 03:18 PM
imported_Max_TL's Avatar
after seeing this thread, went to check my fogs (stock). Car's been out everyday, roads are icy & rutted.
but ????? it's been -30C here for a week now - why not mine - thank god!
Old Jan 14, 2005 | 03:35 PM
LA02MAX's Avatar
like i said before...i dont think it can crack from just being cold as someone stated before...the cold does make it more fragile, but something has to hit it in order for it to crack...and there is no way of telling it cracks "in your driveway" unless you sit out in the freezing cold staring at your foglights all day...so there had to be another reason for it cracking
Old Jan 14, 2005 | 03:39 PM
maximadave's Avatar
detailerdaveb@gmail.com
my passenger side is cracked from the inside but still works...
Old Jan 14, 2005 | 03:58 PM
VQuick's Avatar
Chassis Freak
Glass will break very easily if it undergoes a rapid temperature change. Try taking a glass jar out of the freezer and run it under hot water. It will break unless it's Pyrex, and even then it may break.
I'm guessing he turned on the foglights when the air temperture was -25° or -30°C and those bulbs heat up really quickly.
Old Jan 14, 2005 | 05:43 PM
Burton's Avatar
thanks for all the interesting comments ,it has been -30 here also and I parked the car in the driveway went in house came out 1 hour later and they were cracked, I check all the time as I have gone through fukking many .
Burton
Old Jan 14, 2005 | 05:47 PM
Jaws's Avatar
I've gone through 2 sets of foglights, and 1 set cracked with Armour Sheild film. They are very fragile, but I think that it is rapid temperature changes that kill them. A very poor design
Old Jan 14, 2005 | 08:53 PM
VQuick's Avatar
Chassis Freak
Burton
Yeah, so if you were driving with the fogs on, parked in your driveway and turned off the car, I can see them breaking. Probably going from 100°C + to -30°C quite rapidly, especially given the wind. My advice: do not use your foglights at all until spring if you don't want to keep replacing them.
Old Jan 14, 2005 | 11:06 PM
E55AMG2's Avatar
Wat
There is some company that makes a thick plastic film (its not 3m)...that should help with the cracking. Also, keeping them dry when its cold out is a MUST.
Old Jan 15, 2005 | 08:52 AM
altimized02's Avatar
yep i've ordered the ones off ebay, same as stock, they are the same glass.
Old Jan 15, 2005 | 09:12 AM
soundmike's Avatar
Very sound, Mike
If it's cracked and you don't mind looking at it - keep it the way it is. I've had one cracked and the other with a crack + hole for as long as i've owned the car (3 years now).
Driven through flood water, gone through snow and rain and it hasn't failed on me yet. Amazing how much more dependable the glass on the bulb is compared to the foglight housing lens.
James92SE
142
Jan 2, 2024 09:23 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Andy29
Sep 29, 2015 05:32 AM
msellas
Sep 23, 2015 09:16 PM
