For how long to disconnect Bat. to reset ECU?
Old Jan 16, 2005 | 09:22 AM
nicks79's Avatar
Does anyone know, or timed, how long approx. do you have to keep battery disconnected to reset ECU?
Nick
Old Jan 16, 2005 | 09:33 AM
Ben's Avatar
Ben
If you press the brake pedal after you disconnect, 15 minutes should be fine.
Old Jan 16, 2005 | 09:35 AM
GreenSeMax's Avatar
~1 hour, but I've just done it for a few seconds , just touching the cables together it will ground out the ecu. I'm not 100% if someone has prooved this is a safe way to reset, however that's how I do it, that's how the ford's all get reset, and the ecu still goes into relearn after i do that.
Old Jan 16, 2005 | 09:43 AM
Ammi's Avatar
350 Detroit Muscle
I just leave mine disconnected over night.
Old Jan 16, 2005 | 09:45 AM
nicks79's Avatar
What does it do if you press the break pedal?
Old Jan 16, 2005 | 10:18 AM
Ammi's Avatar
350 Detroit Muscle
Draining..
Old Jan 16, 2005 | 10:24 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
over night.
Old Jan 16, 2005 | 11:29 AM
Sammzway's Avatar
I thought disconnecting the battery doesn't reset ECU? There was a discussion on this before, isn't there a write up on how to reset your ecu? Like tap brake or accelerator certain times and turn on ignition wait couple of second or something in that nature? I'm confused
Old Jan 16, 2005 | 12:04 PM
crispykid717's Avatar
Bigger than Jesus
This procedure is for 02-03's. For 00-01 you just need to disconnect the battery overnight (8-10 hrs).
Old Jan 16, 2005 | 01:11 PM
Y2k2maxse's Avatar
driving style
after you reset the ECU what is different....does it like adapt to your driving habits or something??
matts95max
Apr 23, 2025 10:44 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
220k+ A32
Sep 22, 2015 03:08 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
Colossus
Sep 9, 2015 05:46 AM
