Streaks from b*tches
Old Apr 27, 2001 | 09:43 PM
MaxSEAE's Avatar
Ok, i washed my car today and noticed a couple of streaks on my passenger side door....i think some f***ing b*tch dinged it, scratched it or keyed it....anyhow is there anything that you guys have used that works great in getting ride of this? thanx
Old Apr 27, 2001 | 09:46 PM
DKNYchinito
Try getting them buffed out. You can get this done by a detailer, or your dealership might have people they go to for this kind of work.
Old Apr 28, 2001 | 06:27 AM
UMD_MaxSE's Avatar
Got Bent?
depending on how bad the scratches are, you may be able to use a mild cleaner or body scrub to get them out. If they only affect the clearcoat, you can try a fine-cut cleaner.
Old Apr 28, 2001 | 01:30 PM
killrwheels's Avatar
buy some touch up paint and fill streak in. Then purchase paint repair kit from www.autosupermart.com and it will pull off excessive paint. Kinda expensive at 19.99 for a small bottle. If they are not deep try a sealer and glaze to reduce appearance.
Old Apr 29, 2001 | 01:59 AM
BigDogJonx's Avatar
Like most people already said, if it is a deep scratch, by that I mean if it has dropped below the clearcoat, then you may want to use touch up paint. But most of us know, it only makes it worse cause it never can be applied correctly and what not.
If it not too bad, then like most people said, you a mild cleaner, by that I mean RUBBING COMPOUND. That stuff looks like wax, but essentially it is an ever so soft sanding on the top coat and will smoothen it out the best it can.
Dixit
Dave Holmes
Detailing
Feb 29, 2004 07:31 AM
pauls_93_max
Detailing
Jun 25, 2003 05:33 AM
maximalex
Detailing
Jun 18, 2003 12:10 PM
clipse
Feb 26, 2003 03:11 PM
