Timing Over Advance
Old Feb 1, 2005 | 07:31 PM
joebangaa's Avatar
Timing Over Advance
Has anyone had this code: "Camshaft Position Activator A-Bank 1/2 Timing Over Advance" Two codes they're the same just 1 & 2 that's why i did 1/2...i tried searching. pleeeeaase help me as i dont want to take it to the stealership cuz i JUST hit warranty
In the FAQ they're the first two codes, IVT Control (P0011, P0021)
Old Feb 1, 2005 | 08:24 PM
mikelly's Avatar
ighettoboyi,
This mechanism hydraulically controls cam phases continuously with the fixed operating
angle of the intake valve. The ECM receives signals such as crankshaft position,
camshaft position, engine speed, and engine coolant temperature. Then, the ECM
sends ON/OFF pulse duty signals to the camshaft timing control valve depending
on driving status. This makes it possible to control the shut/open timing of the intake
valve to increase engine torque in low/mid speed range and output in high-speed
range.
The statement you just read above is from my FSM. I'm thinking if you haven't done
your recall issue (Crank Angle Sensor replacement). That might be the problem. Good
luck
Mike
Old Feb 1, 2005 | 08:30 PM
joebangaa's Avatar
i can replace that for free regardless of my warranty right? is it a big deal?
Old Feb 1, 2005 | 08:35 PM
joebangaa's Avatar
i checked the tsb's there's nothing for that...
Old Feb 2, 2005 | 09:03 PM
mikelly's Avatar
ighettoboyi,
The recall work is free regardless if your warranty is out or not. Here's the TSB for your maxima. Hopefully this'll help
Mike
Make : NISSAN Model : MAXIMA Year : 2003
Manufacturer : NISSAN NORTH AMERICA, INC.
NHTSA CAMPAIGN ID Number : 03V455000 Recall Date : NOV 04, 2003
Component: ENGINE AND ENGINE COOLING
Potential Number Of Units Affected : 630000
Summary:
ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.
Consequence:
THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE CRANK POSITION SENSORS. VEHICLES INVOLVED IN A PREVIOUS RECALL CAMPAIGN, 01V357, ARE ALSO INCLUDED IN THIS NEW CAMPAIGN. THE REPLACEMENT SENSORS USED IN THAT CAMPAIGN ARE ALSO AFFECTED. OWNER NOTIFICATION BEGAN ON DECEMBER 22, 2003. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.
Notes:
NISSAN RECALL NO. R3022/INFINITI RECALL NO. R3021. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old Feb 2, 2005 | 09:23 PM
joebangaa's Avatar
Originally Posted by mikelly
ighettoboyi,
Mike
Summary:
Consequence:
Remedy:
Notes:
dang i've had it for almost a week now...truthfully i dont have time tomorrow either. have you had this problem? is it really THAT serious? i know most things arent worth a car crash but dang this just isnt the right time.
Old Feb 2, 2005 | 09:33 PM
mikelly's Avatar
Ighettoboyi,
If it states this can cause a crash, I would take it seriously. I had my recall items done
when Nissan sent me my recall notice. I wasted no time to get it done. It's your choice.
But if you are spitting out codes I wouldn't take any chances. Good luck
Mike
Old Feb 2, 2005 | 09:34 PM
joebangaa's Avatar
argh ok. how long does it take?
Old Feb 2, 2005 | 09:37 PM
mikelly's Avatar
They took about 6 hours to work on my car. I had two other recall stuff they had to
take care of. For yours maybe two hours at best.
Old Feb 2, 2005 | 09:47 PM
Charliejag's Avatar
Just so you know, TSBs are different than recalls. Nissan does not pay for TSB work, just warranty and recall items. I learned this the hard way when I took it in for an ECU TSB.
Old Feb 2, 2005 | 09:51 PM
mikelly's Avatar
Some nissan dealers will do the TSB for free mine does. Most won't so you'll have to
keep this in mind and ask the question. All nissan dealers will do recall items as stated
by charliejag.
Old Feb 3, 2005 | 07:55 PM
joebangaa's Avatar
uhh so is it gonna be free or not cuz i'm going in tomorrow..
Old Feb 3, 2005 | 08:40 PM
Lucky31337's Avatar
Im getting these exact codes on my se as well, the tsb has already been done too, any ideas?
Old Feb 4, 2005 | 05:56 AM
joebangaa's Avatar
dang hope it doesnt happen again. im gonna go in today, glad the car hasn't conked out all week
Old Feb 4, 2005 | 08:16 AM
mikelly's Avatar
Lucky31337,
Are you sure it's the TSB items they did work on and not the recall items? The 02 have
three recall items that needs to get worked on depending on your VIN number. If it's
a recall items which ones did they do. The recall items states crank position sensor
but my dealer replace both crank position as well as camshaft position sensors because
both were in the same bag and they didn't want to have extra parts lying around.
Find out what they did and let us know. At this point I would be guessing..
Mike
Old Feb 4, 2005 | 09:10 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i am not sure of the relationship between your dealer and nissan but my dealer is reimbursed for parts and labor on tsb work. i have many tsb performed and have a close relationship with my dealer and the advisor informed me that they do receive reimbursement as long as they follow the guidelines of submitting it to nissan.
Old Feb 4, 2005 | 10:10 PM
joebangaa's Avatar
the dealer i went to said there's no tsb for this (maybe my vin) but "it should be under warranty" still...
Old Feb 5, 2005 | 06:48 PM
joebangaa's Avatar
so i went to the stealership and left it there for 8 hours and they didnt even do anything but scan a buncha codes!!!! they had to order the part which wont even be here till wednesday or thursday!! they wasted my freakin saturday afternoon and my parents think i'm lying to them when i said i was gone for 8 hours and got zero done. bullsh!t i swear, a dealership should have those stupid parts
Old Feb 5, 2005 | 08:22 PM
Bensmax00's Avatar
hey man. these sensor recalls just dont affect maximas--they affect 350z,muranos, and altimas with 2.5L and 3.5L engines also sentras. this recall should not take that long to do--they probly will say to leave your car depending on the work load of a dealer. the sensors take me about 15 mins on the v6 and 20-25 mins on the on the 2.5L due to the location of the crank sensor(is a real *****). but yeah it is a serious recall--causes no starts or stalling.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
kmitchel
Oct 28, 2015 09:46 AM
Starrider
Sep 17, 2015 07:26 AM
rbaker100
Aug 31, 2015 11:09 AM
305head
Aug 26, 2015 09:03 PM
