Does anyone else have the CAI besides Y2Kev?
Old Apr 29, 2001 | 11:03 PM
RBa's Avatar
RBa
If so...Can you post some pics(Not OSCAI) please? I wanted to see how it was done b/c...
My freakin fuse box on the driver's side wont fit... I measured with the template again to see if I drilled the wrong hole but found nothing wrong..
Do I have to blame Cattman for this?
And Clee...
Can you send me the 2 or 3 pics you took?
Thanks.....
Old Apr 30, 2001 | 06:59 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Nope... don't blame Cattman on this because he didn't make the PRCAI... Place Racing did. Try fidgeting with the tube and fuse box again.
Old Apr 30, 2001 | 03:40 PM
RBa's Avatar
RBa
Wow!!! So out all the ppl on the org, You & I are the only 5th gen owners with a CAI..
What's up with that? Did everyone go ooglie stock?
Old Apr 30, 2001 | 04:35 PM
psing23's Avatar
<~~~~ OSCAI HERE
Old Apr 30, 2001 | 06:21 PM
ispeed's Avatar
Well I'll soon be wit ya!!! Got mine through the group deal, and they are finally sending it ... blame place racing for that!!!! Mine is scheduled to arrive tomorrow, so I'll let ya know if I had any trouble.
Keep your fingers crossed
Old Apr 30, 2001 | 08:24 PM
Y2KevSE's Avatar
I thought there were more people than us.....
Old Apr 30, 2001 | 10:37 PM
footemps's Avatar
what's prcai?
Old Apr 30, 2001 | 10:40 PM
Y2KevSE's Avatar
Place Racing Cold Air Intake... http://www.cattman.com for more info
Old Apr 30, 2001 | 10:41 PM
RcticMax's Avatar
Originally posted by footemps
what's prcai?
Place Racing Cold Air Intake (psst... check the parts list "sticky thread" at the top of the forum before somebody gives you the smackdown )
Old May 1, 2001 | 05:24 AM
1HOTMAX's Avatar
me me me
i got one and mine looks pwetty!!!!! told you man, take the bottom piece off. stop the b!tching already, i had to remove so much stuff on my ride, at first it feels funny, but after a while, ya get use to it, and no water will get there, it's too high..............besides, it's just wires!!!! use elect tape if it bothers you or wrap w/ foam or loom from a vacum hose
Old May 1, 2001 | 07:15 AM
Y2KevSE's Avatar
You're a 4th gen so you don't count!
Old May 1, 2001 | 12:49 PM
nvmymax2's Avatar
PRCAI Intake...
The easiest way for me was to just take everything out of that side of the engine bay and then get someone to hold the wires back while you cut the hole. But hey don't listen to me my check engine light has been on for the last twenty thousand miles. But my car runs fine and everything works. Also just leave the white piece from the underside of the wires off and wrap it with some kind of insulation. You shouldn't have any problems with it fitting then.
Old May 1, 2001 | 12:55 PM
nvmymax2's Avatar
PRCAI Intake...
Old May 1, 2001 | 02:34 PM
QUANSUNG
Re: PRCAI Intake...
i'm considering getting the pully or prcai ,i know the cai gives more power but i'm worried in case i have to go in for warrenty work and trying to explain the 3" hole .
Old May 1, 2001 | 02:40 PM
punkdork's Avatar
Re: Re: PRCAI Intake...
Go for the UDP and OSCAI. You can do PRCAI after your warranty is up.
Old May 1, 2001 | 02:46 PM
RBa's Avatar
RBa
Re: PRCAI Intake...
nvmymax2...
Your Check engine light has been on and you didn't have any probs resulting from it?
Old May 1, 2001 | 02:47 PM
Slim Shady's Avatar
I've got a PRCAI on my AE it took a little bit of moving around though
Old May 1, 2001 | 02:50 PM
punkdork's Avatar
Old May 1, 2001 | 04:49 PM
Y2KevSE's Avatar
Re: Re: Re: PRCAI Intake...
But he'll have to remove the UDP for warranty work... unless he gets the black one.
Old May 4, 2001 | 05:26 AM
PIONEER's Avatar
Re: Re: Re: Re: PRCAI Intake...
I have one question for you guys. When the CAI is installed. do you remove the plastic covering underside the car that covers the fog lights or leave that thing alone? The issue is how do I get air in that hole and not water? If I remove it, then in the rain water from the tires will feed right into the intake. Any Suggestions on that??
Old May 4, 2001 | 07:18 AM
Y2KevSE's Avatar
Re: Re: Re: Re: Re: PRCAI Intake...
I left mine on... I've seen someone that took the cover off so the filter is completely exposed.
Old May 4, 2001 | 07:59 AM
PIONEER's Avatar
Re: Re: Re: Re: Re: Re: PRCAI Intake...
Is that dangerous? Kev I looked at your pic. U didn't take any pics with the tube by itself without the filter installed. when your tube sticks out of the bottom, is it straight or is it pointing backwards a bit? Also does your filter touch the plastic piece on the fender?
I am wondering cars like the Sentra and others don't have the plastic covering like the maxima does and their filter is exposed. so how safe is that when U go through puddles or in heavy rain?
Maxima_Joe
Nov 25, 2015 08:19 AM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
BGTONIO1991
Aug 11, 2015 07:38 AM
