How can I tell if a 5th Gen has LSD?
Old Feb 14, 2005 | 09:05 AM
Xenolite's Avatar
Hi
I'm looking to buy a 2002 6Spd, but everytime I ask the sales person about LSD they ussually don't know what it is or confuse it with Traction Control.
Is there anyway I can tell if the car has LSD without driving the car hard?
Thanks.
Old Feb 14, 2005 | 09:27 AM
RacertilTheEnd's Avatar
If I am mistaken, all the 5th gens have LSD.
Old Feb 14, 2005 | 10:00 AM
spirilis's Avatar
Drive it and see if you trip
No, not all 5th gens have LSD. Of the 2000-2001 models, I think only the AE edition had the option of VLSD, and that was on the 5spd only (?)
2002-2003 I think the 6spds had the option, and it was an HLSD design?
I believe LSD-equipped cars are identifyable by the pedals--if they're metal drilled as opposed to plastic?
Old Feb 14, 2005 | 10:58 AM
max5spd's Avatar
Says.."No mo Maximas for me!"
You are mistaken. Spirillis is partially correct. Stock wise, the pedals do signify that HLSD is present. However, many of us have added the pedals and we do not have HLSD. I believe the plate that's on the firewall will definitively identify whether or not you have HLSD.
Old Feb 14, 2005 | 11:40 AM
makavelisk's Avatar
From a former post...
"Anyway, here is what you have to look for on the plate in the engine bay:
The engine code will read : VQ35(DE)
If you have a 6 speed with an open differential, the code will be: RS6F51A
A as in open diff
If you have a 6 speed with a Helical Limitd Slip Differential the code will read RS6F51H
H as in Helical."
Old Feb 14, 2005 | 12:39 PM
Real quick refresh of my memory... limited slip differential is the same concept as positraction, where the car is driven by two drive tires instead of just one, correct?
Old Feb 14, 2005 | 01:01 PM
makavelisk's Avatar
Yup.........similar but still different
Old Feb 14, 2005 | 01:06 PM
Yeah, I understand that they are still different. What I am asking is how come both of my front tires can leave nice tread marks on the asphault when my non-posi '96 camaro only would leave one tread mark from the drive tire? Do I make sense?
Old Feb 14, 2005 | 01:23 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Not different in overall mechanical functionality, but different in name. Positraction is just the General Motors (GM) moniker for a limited slip differential. Chrysler's limited slip is called Trac Lock. They all have their little gimmick names. They are the exact same same thing mechanically, though...
There are different mechanical engagements and different systems and styles, but they do the same thing.
Old Feb 14, 2005 | 01:25 PM
OT n00bs FTMFCSL
A limited slip will divide the power evenly between the two wheels (hence the two stripes) vs. an open differential which will provide the most power to the wheel with the least resistance (the one already spinning)...
It can be much more complicated than that, and it usually is today as there is more technology involved in the modern LSD. Today's LSD's can limit power to wheels that are losing traction and deliver it to the other side to keep overall control of the vehicle...
I could explain this stuff all day as there are many different types of LSD's now...
Old Feb 14, 2005 | 04:31 PM
Xenolite's Avatar
A as in open diff
H as in Helical."
OK thanks alot! This definately helps. I will check the engine code.
Old Feb 14, 2005 | 04:48 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
to answer your question, the auto ae has the same vlsd as the manual.
Old Feb 14, 2005 | 05:29 PM
Jaws's Avatar
To be a little more specific, its the transaxle code you are looking for, not the engine code. Its on the firewall inside the engine compartment.
Old Feb 14, 2005 | 06:23 PM
So does that mean that I have LSD on my 2000 GXE, because I leave two tire treads, not one.
Old Feb 14, 2005 | 06:29 PM
OT n00bs FTMFCSL
not necessarily. Sometimes an open diff will leave two stripes...but not that often...
Old Feb 14, 2005 | 06:41 PM
MCE's Avatar
MCE
For a 2001 Max the I.D. numbers for the 5 speed LSD are RS5F50V. The auto LSD numbers are RE4F04W.
MCE
Old Feb 14, 2005 | 06:42 PM
hmm... if I do not have a LSD, I want one. Where can I get one for my car?
Old Feb 14, 2005 | 06:46 PM
MCE's Avatar
MCE
As far as I know you would have to swap out your tranny.$$$$$$
MCE
Old Feb 14, 2005 | 06:48 PM
Oh yay!!! Hmm... does anyone have the numbers for a 2000 with lsd?
Old Feb 14, 2005 | 06:53 PM
upstatemax's Avatar
i always leave two burn out marks.... does an auto 00' SE have a limited slip option?
Old Feb 14, 2005 | 07:39 PM
Jaws's Avatar
No. It more than likely means that both tires had the same amount of grip.
Old Feb 14, 2005 | 10:26 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
5th gen 3.0Ls only the AE versions had VLSD- which is viscous limited slip differential, 02-03 had the option of a Helical Limited Slip diff- hence HLSD. HLSD only comes on the 6spd tranny, which is shared with Spec V SE-R and the new Tiburon.
Old Feb 14, 2005 | 11:25 PM
I always leave two tread marks too. Where could I get a AE 5-speed tranny? And would it bolt on to my GXE?
Old Feb 16, 2005 | 06:47 PM
Anzioblack44's Avatar
hmm, So no one manufactures an aftermarket LSD for the Auto tranny. Ive come across torque converters and shift kits, no differentials
Old Feb 16, 2005 | 11:11 PM
Will an AE tranny bolt onto my GXE. And if yes, where can I find one?
Old Feb 17, 2005 | 05:43 AM
max5spd's Avatar
It would probably fit. Try a junkyard.
Quaife doesn't make an LSD for our cars yet?
Old Feb 17, 2005 | 10:59 AM
Well damn. Lucky enough for me, my uncle owns a junkyard, and my family works with a salvage yard. So I am on my hunt to find the tranny for my maxima.
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
220k+ A32
Sep 23, 2015 03:38 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
