Keyless Remote Instructions...Help
Old Feb 16, 2005 | 07:28 PM
DaReaper9's Avatar
Sup All...
For those of you who yell @ ppl who don't search b4 posting, I did...Im trying to locate the programming instructions for the keyless remotes...
Any help is appreciated!
Old Feb 16, 2005 | 08:23 PM
maray's Avatar
here you go...
Remote Programming
I've used it and it works...
Old Feb 16, 2005 | 08:28 PM
E55AMG2's Avatar
Wat
there was a thread about this not 5 days ago.....
Old Feb 16, 2005 | 09:26 PM
DaReaper9's Avatar
Thanks...A-pwe-she-ate-it Mucho!
Old Feb 16, 2005 | 09:35 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Also, I posted a thread about those instructions not being entirely correct. It takes some self discovery. An elightment email was sent to Courtesy with no reply.
Old Feb 16, 2005 | 09:42 PM
bigsherv's Avatar
Here are directions again
IMPORTANT: Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Old Feb 17, 2005 | 04:50 AM
maray's Avatar
The Courtesy instructions worked fine for me on the first try...
Old Jul 10, 2005 | 02:46 PM
n3985's Avatar
大陆弟弟
Sorry to bump an old thread. But can someone clarify step #7 please? It says:
Step 7) Push any button twice on remote controller once, (Hazard warning lamps will then flash twice). At this time, the oldest ID code is erased and the new ID code is entered.
So do I press any button once or twice? Thanks...
Old Jul 10, 2005 | 07:14 PM
jasba's Avatar
Yeah that one got me too....I think I just pressed it once and it was good to go....
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
