p0420 again
Old Feb 23, 2005 | 08:50 AM
turkey72's Avatar
p0420 again
I went to the stickies and can't get a straight answer. Is it the upstream o2 sensors or the one after the cat. The car runs fine just cel light stays on. I( I have an emission test soon and would like to get this fixed. As common as this problem is someone has to have had this exact problem.Thanks
Old Feb 23, 2005 | 08:54 AM
philzaga's Avatar
i have the same problem. gotta get it fixed soon. i got two codes for both sensors so ill just have to change both i guess.
Old Feb 23, 2005 | 08:56 AM
turkey72's Avatar
Also the car is a 2000 model, forgot to mention it.
Old Feb 23, 2005 | 09:17 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
get used to it...... you can fix the sensors but it will come back....
Old Feb 23, 2005 | 10:35 AM
Love_00_Max's Avatar
I got this code last month and went ahead and bought the O2 simulator (http://www.o2simulator.com/) which kind of fools the ECU that a good sensor is out there -- I have not got the code since installing this hardware. Hope this helps...
Old Feb 23, 2005 | 11:48 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Since apparently you can't read, UNLESS YOU HAVE A FED SPEC 2000, this TSB is your answer:
http://forums.maxima.org/showpost.ph...8&postcount=25
Komax
Mar 11, 2005 03:04 PM
killer924007
Dec 8, 2004 07:46 PM
cyclecrazy55
Nov 1, 2003 01:18 AM
dashingMax
Aug 24, 2002 04:59 AM
