Screeching sound right after start up.
Old Feb 23, 2005 | 09:55 AM
hokiemax's Avatar
Hi. My car makes a screeching sound for a split second right after I start up the engine.. anyone has a clue what it might be? I remember reading somewhere that it could be a belt issue. What do you think?
Btw, the car is a 5spd 2000 GXE with 90k miles. The belts have never been replaced yet.
Old Feb 23, 2005 | 10:13 AM
NYPD-Arnold's Avatar
Z
Does it kind of sound like the screech when you accidentally turn the key, meanwhile the car is already on?
Old Feb 23, 2005 | 10:16 AM
Pri63's Avatar
it's probably the starter, my max does the same...you in blacksburg?
Old Feb 23, 2005 | 10:23 AM
hokiemax's Avatar
yup it sounds exactly like that. Have any ideas ?
And no, i'm not in Blacksburg anymore. Been out of school for few years now.. I miss the place terribly. But I still go to almost all home games.
GO HOKIES !!!
Old Feb 23, 2005 | 11:04 AM
Y2KMaxGXE-R's Avatar
replacing the belts won't hurt, could be them..is there any correlation between the weather and the noise: like starting in the rain vs. dry sunny weather?
Old Feb 23, 2005 | 11:06 AM
NisMo-Max's Avatar
If the car is being warmed up and has a screeching sound near the crank/belts, then you need to replace the belts....
Old Feb 23, 2005 | 11:31 AM
SlowJoeMax's Avatar
my car has made a screeching noise when i first tried to start it, then i turn the key again and starts...its done it twice, only when its cold out
Old Feb 23, 2005 | 12:26 PM
Z
It's probably the starter. Belts shouldn't make a screech that sounds like the ignition is grinding. Belts make more of a whine, not a screech.
Old Feb 23, 2005 | 01:23 PM
BLUEMAX01SE's Avatar
try spraying some wd-40 on the belts to see if it still does that noise afterwards.
Old Feb 23, 2005 | 01:24 PM
JaMdMax97's Avatar
Mine did that for awhile then my starter finally gave out, and after i got a new one put it theres not more sreeching sound...
Old Feb 23, 2005 | 01:35 PM
nyautostyle's Avatar
I had this problem and replace the betls, tension etc. about a month ago.. and now its starting again.. I'm actually stopping by my mechanic now to see whats up, i'll keep you guys posted. Also if this happens again, anyone know a good mechanic on long island near nassau?
Old Feb 23, 2005 | 01:47 PM
SkoorbMax's Avatar
My 00 does it. I think it's the starter, though possibly the timing chain tensioner, though I've not _heard_ how these two possibilities can sound different, though I know both do cause start up sounds.
Old Feb 23, 2005 | 01:52 PM
Love_00_Max's Avatar
A screeching sound meaning "starter" -- the starter needs to be regreased. I did this a while back and haven't had cold start screeches since then. I had a detailed writeup posted on a similar thread some days back....
Old Feb 23, 2005 | 02:26 PM
2000 Maximus's Avatar
Yup just as said above, the write up is great for this "screeching sound" - It is the Starter grease that makes the noise when the car is started at a cold temp. I bet the sound doesnt happen to all you guys when the weather is nicer and warmer out, i know myself cause i have the same problem.
The starter regrease writeup will help our increadibly, but it does take some time to get to it.
As far as belts go and the tensioner, replacing them cant hurt (just the keep the car running smoothly and effiecently) but it be the 'right' fix for the problem at hand.
Hope this is a better explaination to the problem.
Old Feb 23, 2005 | 02:54 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
IT IS THE STARTER!!!!
http://forums.maxima.org/showthread....09#post1775009
Old Feb 23, 2005 | 03:01 PM
i think its the tension, that its loose, could be the starter as well, like they said... but im gonna put the car up tomorrow and see whats going on
Old Feb 23, 2005 | 04:58 PM
Ammi's Avatar
350 Detroit Muscle
On my other car, it was due to worn out alternator belt. Replaced it and sound was gone.
Old Feb 26, 2005 | 08:20 AM
Okay so i realized i got a defected pulley from nissan, which i replaced... So now I got this other noise still there, It seems like the compressor to me but my mechanic said its not that. Oh and He doesnt know what it could be.... great mechanic let me tell you. Im going to bring it to nissan and see whats up hopefully next week. It sounds like im driving a buick or something, its horrible. Oh yeah and now my radiator is cracked, and leaking from the top. I'm having a great day over here..
boomerbrian
Oct 31, 2018 10:25 AM
pktaske
May 6, 2016 07:49 AM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
