clutch problem...please help
Old Feb 28, 2005 | 09:22 PM
nytrida's Avatar
I adjusted my clutch height by loosening the 14mm bolt that's connected to the rod with the electrical housing on it and turning it clockwise five times. AFter this, my clutch release point has been changing up and down. It first was at the middle, then it went to the floor and then the clutch became stiff and the release point was towards the top. Today morning i backed it up a little by turning the rod counter clockwise two times, therefore having the rod turn a full three clockwise turns. The relase point still seems to be moving. The clutch does not seem engaged because i don't smell it. I've driven about 150 miles or so. Anybody have any suggestions???
Old Feb 28, 2005 | 10:17 PM
nytrida's Avatar
anybody?????
Old Feb 28, 2005 | 10:31 PM
lex3015's Avatar
i dont know man, honestly swinging by a local mechanic or asking a friend who might know whats up with fixing cars might be able to check it out. sounds like you didn't quite do something right, which is just stating the obvious. hope it works out for you, best of luck.
Old Feb 28, 2005 | 10:45 PM
nytrida's Avatar
it's one nut...and turning a rod....i can't imagine how something would go wrong...
Old Mar 1, 2005 | 03:51 PM
StAtiXz6's Avatar
been there done that.....ur burning ur clutch..
Old Mar 1, 2005 | 03:54 PM
LA02MAX's Avatar
raise it..you turned the bolt WAAAY too much..i turned it twice and my cruise wasnt working, so that was too low...just put it back to the way it was...
Old Mar 1, 2005 | 04:14 PM
willkim's Avatar
You adjusted the wrong one. You should be using a 12mm bolt BEHIND the clutch. It's harder to reach than the 14mm one. There was a looooong thread on this a couple pages back.
If you read the thread/how-to carefully you should be adjusting the 12mm bolt BEHIND the fork that holds the clutch. Loosening that bolt will make it travel towards the firewall, allowing you to shorten the clutch travel length. You take out the cotter pin, remove the fork and turn the FORK (NOT THE ELECTRICAL HOUSING) clockwise to shorten, counter to lengthen. I found that 2 full turns was perfect.
AFTER you do find a good height you THEN adjust the 14mm bolt and the electrical housing (in front of the clutch right?), and adjust it JUST enough to depress the Cruise Control Sensor. (this is only necessary, if you use cruise control. This should NOT adjust the clutch travel distance)
if you only adjusted the electrical housing closest to you... you're frying your clutch, man. it's like putting your foot on the clutch half way the entire time. (didn't you get high revs?)
Now that you know how to do it... are you sure you want to? Once adjusted, the spring is never fully released, making for a "sloppy" feeling. Also, there is still debate going on whether or not the shorter distance is bad for your clutch.
Old Mar 1, 2005 | 04:19 PM
LA02MAX's Avatar
http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
here's the detailed instructions i used..it would have worked, but i adjusted it a little too low... it was nice while it lasted though!
Old Mar 2, 2005 | 07:30 AM
nytrida's Avatar
After you turned the fork two clockwise turns, how many clockwise turns did you do to the electrical housing rod?
Old Mar 2, 2005 | 09:28 AM
Fezzik's Avatar
I didnt have to turn the fork. I just release some pressure from the clutch and turned the rod.
Old Mar 2, 2005 | 09:35 AM
LA02MAX's Avatar
you just have to turn the fork to get it away from the bolt you're trying to turn....if you look, the smaller bolt is hidden way up passed where the fork attaches
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
