Security light constantly lit
Old Mar 2, 2005 | 01:47 PM
buffalodiddle's Avatar
Hi,
What does that indicate? Before someone says "use the search function", it's disabled so I can't.
Thanks in advance.
Old Mar 2, 2005 | 02:17 PM
Maxima2000SE's Avatar
it should be in your manual and off the top of my head i think it means your security system is obviously malfunctioning and to have it looked at but beyond that i am not sure.
Old Mar 5, 2005 | 02:43 PM
Thanks. The manual says that it needs to be checked. I'm trying to find out what to check.
Old Mar 5, 2005 | 02:46 PM
LA02MAX's Avatar
Originally Posted by buffalodiddle
Hi,
Thanks in advance.
just to let you know, you have to donate in order to use the search function...
Old Mar 5, 2005 | 03:06 PM
You don't know either?
Old Mar 5, 2005 | 07:15 PM
Anybody know the answer to this? I'm just looking for a list of possible causes.
Old Mar 5, 2005 | 07:29 PM
Zero Deuce SE's Avatar
What year is your car?
Old Mar 5, 2005 | 07:31 PM
Not mine. It's a 2001.
Old Mar 5, 2005 | 07:37 PM
slizan99's Avatar
it means that there is a NATS code. thats the chip-in-key security feature of the maxima.
Old Mar 5, 2005 | 07:42 PM
Looking in the 02 FSM, it's probably a switch or something. It's much easier to have it connected to the Consult tool.
Old Mar 5, 2005 | 07:47 PM
Thanks. Any connections or modules we should check? That is, could it be something stupid? It just started. Don't really want to go to the dealer just to have them jumper something or wiggle some connectors.
Old Mar 5, 2005 | 09:35 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
check the hood switch under the hood- by the battery. Alot of times that thing gets corroded and looses connection with the body controll module and alarm. It could also be one of the door contact switches- does your interior light stay on even with the doors all closed ? if YES then check the door switches one by one- they are switching ground switches. It could also be a bad trunk latch switch, but most likely it will be the under hood switch which is right by the headlight/battery- look for corrosion in the harness connector or even a broken switch.
Old Mar 5, 2005 | 11:47 PM
Excellent! Just the info I was looking for.
Thank you all for your help.
Maxie40
Sep 14, 2015 11:28 AM
minsbang
Sep 11, 2015 08:48 PM
Maxima30
Sep 7, 2015 06:13 PM
jfl330
Sep 4, 2015 01:44 PM
