Once the ECU is reprogrammed....?
Old Mar 3, 2005 | 07:52 AM
nicks79's Avatar
I need to reprogram my ECU, its been disconnected few times and MAF installed and I think it needs that Fuel Cut TSB thing. Now, I plan on changing the clutch, and that will include disconnecting the battery for the time of service. If I reprogram the ECU now, will all that be gone and back to factory settings once I unplug battery for a long time? or is ECU written in some other flash ROM that its not affected by disconnecting the battery.
I think it will set it back to factory if I unplug the battery. Am i correct?
Old Mar 3, 2005 | 09:20 PM
Lytheum's Avatar
if you have the dealer flash the ecu you will be ok. the only settings you lose are the ones you manually have to change. like advanced timing and stuff.
Old Mar 4, 2005 | 08:55 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Where do you guys come up with this stuff?
Disconnecting the battery ONLY erases stored DTC codes(2000-2001 only) and "learned" values for fuel enrichment/leanment(short/long term fuel trim). It does NOTHING to dealer FLASHED program data or timing/idle parameters.
Think about it logically and how often do you think people have batteries die/alternators die/disconnected batteries for work under the hood, do you REALLY think that would "erase" EEPROM in the ECU?
Although the dealer could make more money if that was true, they'd be swamped reflashing peoples cars every time constant power was disrupted.
This is NOT your alarm clock with no battery backup we are talking about here.
Old Mar 4, 2005 | 09:05 AM
GBAUER's Avatar
Thank you ICY! A lot of info here is "misleading" in that it is 180 degrees off correct. Good to see that at least some can be corrected.
Old Mar 4, 2005 | 09:04 PM
Lytheum's Avatar
i was told that by a nissan mechanic...but i asked in another thread...heh...guess i was wrong
Old Mar 5, 2005 | 08:43 AM
rule da road's Avatar
Can anyone describe this fuel cutoff? I know i need a maf, i cant get past 3200 rpm in a manual. I have no power in the entire band and this after unplugging the battery for a few hrs. Will a reprogram bypass the "learning" process of the ecu?
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
