how to for installing hella horns
Old Mar 9, 2005 | 04:25 PM
The Kid's Avatar
does any one know where the how to to install hella horns is if there is one and what parts will i need to connect them thanx you.
Old Mar 9, 2005 | 05:09 PM
Ammi's Avatar
350 Detroit Muscle
it's not that hard. One wire for + and the other wire is ground. You can mount them at stock location too
Old Mar 9, 2005 | 05:33 PM
The Kid's Avatar
ok one wire for each now were does the oem horn wire go so when i honk the horn with the sterring wheal it goes off thanks
Old Mar 9, 2005 | 05:45 PM
Ammi's Avatar
350 Detroit Muscle
plug the OEM to + side and ground the other wire
Old Mar 9, 2005 | 06:00 PM
bsetiawan's Avatar
You can actually plug the OEM wire to any of the terminal. Then connect the extra terminal to a ground point (such as the chassis or battery -ve). There is no polarity to the terminal on the horn.
Old Mar 9, 2005 | 08:02 PM
Max20SE00's Avatar
yeah what they said, it's a really easy process. Plug and play, you just have to ground the other terminal
Old Mar 9, 2005 | 08:19 PM
Max20SE00's Avatar
also, have fun installing the horn behind the grille. It took me awhile and some torn up hands to get it bolted on.
Old Mar 9, 2005 | 08:32 PM
irish44j's Avatar
retired moderator
so true.....so true......
Old Mar 9, 2005 | 08:53 PM
whazzzzuup's Avatar
Here are some pictures of my 5 minute install. No bumper = no scratches on hands.
Old Mar 10, 2005 | 08:20 AM
PO-POMAX2K's Avatar
For the second horn did you splice the factory wiring from the rear factory location? or did you do all the splicing with the front mount? Mine are currently in the stock locations but I want to move both up front.
Old Mar 10, 2005 | 09:45 AM
abakalen's Avatar
On 2K2 and 2K3 both horns are mounted on the front from the factory.
I just installed hellas today on my car during lunch break, they look pretty aggressive and they are loud
Old Mar 10, 2005 | 10:02 AM
PO-POMAX2K's Avatar
Oops didn't notice what year the car was. Anyway anyone with a 5th gen 2k-2k1 have any insight.
Old Mar 10, 2005 | 10:36 AM
Ammi's Avatar
350 Detroit Muscle
Are you trying to mount them side by side behind the grill?
Old Mar 10, 2005 | 11:26 AM
PO-POMAX2K's Avatar
Yep. 12345678.
Old Mar 10, 2005 | 01:40 PM
Ammi's Avatar
350 Detroit Muscle
Yep. 12345678.
take a look at the diagram that comes w/ the horns. It's pretty straight forward
Old Mar 10, 2005 | 01:41 PM
XGaSpAcHo
i've got a question about these. do you have to cut the little clips that hook on to the factory horns with these or do the clips just hook right on?
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
