restricter behind tb
Old Mar 12, 2005 | 03:41 PM
xlcrew's Avatar
I’m Back
i had to replace my iavc today and when i took the tb off i found what looked like a restricter. is it ok to remove it does anyone know what it's for?
Old Mar 12, 2005 | 04:02 PM
spirilis's Avatar
There was a thread about this. It won't hurt anything, but I'm not sure if it'll do a whole lot for you. Part of it seems to be a protrusion that guides air smoothly into the manifold I think...
Old Mar 12, 2005 | 04:04 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
not sure if anyone ever found a specific reason for it being there. i removed mine about 6 months ago with no issues. comparing the plate and tb size wise, it is obvious that it is a a restriction. some people said they felt a low end loss when they removed it but i have not experienced anything of the kind. i also found as others did that there was paint missing from it. only one place it could have gone and i would like to limit the amount of paint my engine takes in.
Old Mar 12, 2005 | 04:26 PM
xlcrew's Avatar
I’m Back
so i guess me taking it out won't hurt anything and i hope that when i put my supercharger on it will like it a lot, thanks guys
Old Mar 12, 2005 | 11:48 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Some people that removed the restrictor found a more pronounced intake whistle when crusing or accelerating at part throttle. I like the whistle, and I been driving without mine for about a year now. No noticable gains or losses in power here.
Old Mar 13, 2005 | 09:27 AM
Galo's Avatar
Maxima Pilot
Mike is right on, I also removed it and noticed a much more pronounced whistling, a slight drop in low-end TQ and more important, about a 75 rpm higher idle.
I did not like that and figured it's mostly due to removing the tongue-looking thing at the bottom of the restrictor which is prolly an air flow guide and also because the lower portion of the restrictor (below the tongue-looking thing) actually covers up the part of the TB where the idle air is controlled......that's probably why removing the restrictor caused my idle RPMs to go up a bit.
My fix for all this was to take a Dremel and open up the part of the restrictor that's above the tongue-looking thing to match the manifold, leaving everything beneath the tongue-looking thing (what I presume to be an air guide) untouched.
The RPMs dropped back to normal, the whistle quieted down dramatically -although you can still hear is a wee bit- and more important, the car does indeed feel a bit better on the top end -at least with a butt dyno. I've had the modified restrictor in the car now since summer with no ill effects nor negative impact to fuel mileage.....
Old Mar 13, 2005 | 09:31 AM
xlcrew's Avatar
I’m Back
i love the whistle sound, and it's definitly a little bit louder than before
Old Mar 13, 2005 | 12:24 PM
spiromax's Avatar
Seoul Man
subscribe (because I can't find the "Subscribe to this thread" button)
Old Mar 13, 2005 | 01:08 PM
sloppymax's Avatar
i noticed the higher whistle as well but no change in rpm for me. i had it logged before with my harrison odb software on my laptop and afterwards with no variation.
Old Mar 13, 2005 | 03:50 PM
I30swimmer's Avatar
did you notice any gains? would it be worth my time taking the TB off? cause i generally clean it with just the Air-box removed so i havent ever taken off the TB
Old Mar 13, 2005 | 04:50 PM
SoonerFan's Avatar
Cletus
i removed mine about a year ago. havent noticed any positive or negative effects
Old Mar 13, 2005 | 05:24 PM
scopium
how do u remove this thing?
Old Mar 13, 2005 | 06:14 PM
sloppymax's Avatar
i took it off because i simply look it as a restriction. i would not say this gained power but it makes sense removing something that restricts air flow into the motor, especially with how small the opening is compared to the tb. as to the other question, remove all the air intake then the 4 bolts on the tb. you can unplug the connectors going near the tb for easier access or just work with it and pull the plate out. like i said before as well, i think it is worth removing just so the more paint does not peel off and go into the motor.
Old Mar 13, 2005 | 08:08 PM
mad2kmax's Avatar
I've had mine removed for quite a while now and have had no problems. The whistle is louder, but I kinda like it. Just like a few have said, it was a restriction and the paint was chipping on mine as well.
Old Apr 2, 2005 | 03:24 PM
spiromax's Avatar
Seoul Man
Nobody is going to read my new thread on this matter, because it contains no relevant information. Now that I've found this thread, I think it would be better for the forum as a whole if I posted my questions and findings here instead of polluting the forums with a new long thread. Anyway, here's what I found when I took off my throttle body to clean it.
"I just took apart my intake and removed my throttle body to clean it. As far as I can see, there's nothing that even remotely looks like a restrictor plate between the throttle body and intake manifold. There's a thin metal ring, but it has the same diameter as the TB/IM, so it's not restricting flow at all. There's also no "tongue" or other protrusion to direct incoming air.
Most of the threads I've seen regarding this plate are from VQ30 owners. Does the VQ35 not have this plate at all?"
Old Apr 2, 2005 | 10:23 PM
xlcrew's Avatar
I’m Back
probably not, different intake system different motor
Old Apr 3, 2005 | 04:12 PM
sloppymax's Avatar
the 3.5 does not have the same plate in the manifold. major reason and probably only reason are the manifolds are completely different.
cruce91
Sep 20, 2015 10:23 AM
coasterswim
Sep 1, 2015 05:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
1992maximase30
Aug 5, 2015 09:27 PM
CandiMan
Sep 23, 2001 11:51 AM
