All SE Owners and Aftermarket Struts
Old Mar 16, 2005 | 11:48 AM
rLx77's Avatar
I got my new Tokico HP Blues sitting at home. I don't plan on putting on new springs, but keeping the stock SE springs and installing the new struts.
If you did a similar thing thing as me, how did you like the car after the struts installation? Was the ride quality better or worse? Was the handling better or worse? What was your objective to replacing your struts (more handling, better ride quality, blown struts)?
Any kind of feedback/comments are greatly appreciated in advance. Thank you all.
Old Mar 16, 2005 | 11:53 AM
Puppetmaster's Avatar
Put on HP/Progress about 4000 miles ago... I LOVE IT...
Ride quality is definitely less cushy, but has a "sportier" feel to it, ie. its harsher than stock although not uncomfortable (I'd give it 7.5/10 with stock being 10); its actually pretty nice still...
Handling has improved by a ton, so has stability at high speeds...
Yeah, I know... I didn't use the stock springs like you're planning too... but just thought I'd share anyhow... the HPs are slightly stiffer than stock, so you'll probably see some improvement in handling and it'll feel more solid... but still a nice ride cuz of the OEM springs...
Old Mar 16, 2005 | 12:08 PM
TDotMax's Avatar
Sorry to be off topic, but I thought I was the only one who noticed the max was unstable at high speeds. I thought it was jsut my winter tires
Old Mar 16, 2005 | 12:18 PM
rLx77's Avatar
Instability at high speeds, your alignment might be off. Mine is off right now, and when I'm driving at 70mph or so, it's not stable. Also can be from strong winter wind gusts, and if your struts are worn, you'll feel the car shift from teh wind.
Old Mar 16, 2005 | 12:45 PM
rLx77's Avatar
bumppppppppppppp
Old Mar 16, 2005 | 01:42 PM
BudVlad's Avatar
I have stock struts and springs on my 01 SE. At 160 km/h on winter bridgestones the car is very stable.
Old Mar 16, 2005 | 03:21 PM
serin's Avatar
rlx77: you and i were in the same boat. looking for cushy ride. i ended up with illuminas and gle springs. see thread here
http://forums.maxima.org/showthread....16#post3771216
illuminas at the 2 setting are supposed to be similar to the blues. currently i have em set at 2 in the front and 1 in the rear. DEFINITELY better than before with se springs and blown/worn struts. but nothing close to the ride of my acura. i'm happy tho knowing there wasn't much more i could do. i take that back. i suppose i could remove the fstb and rsb, but that's not in consideration right now cuz i need them to handle the extra roll from the softer suspension. it's a balance i guess.
btw, the gle springs were only $25 from an orger
Old Mar 16, 2005 | 06:09 PM
young1976's Avatar
why did you replace your SE spring for GLE? Aren't GLE spring a bit softer? Or did you want a softer ride. When I need to change struts, I think I'm going to use the stock SE springs with Illuminas. I don't want to lower my car.
matts95max
Apr 23, 2025 10:44 AM
dvcamp
Sep 18, 2015 10:17 AM
catalinvint
Sep 16, 2015 07:48 PM
A32goldylocks
Sep 16, 2015 01:33 PM
