tint removal question/concern
Old Mar 17, 2005 | 11:08 AM
takkar's Avatar
I bought my car 2nd hand and i guess the previous owners used a ammonia based cleaner to clean the windows since the tints are now purple. How can i remove them( iw ant to get new ones installed and the local shop is asking as much to remove it as to put new ones on)?
Someone mentioned that I should try it with soap and water...but then wouldnt soap and water drip inside the door ( inside the trim and door?)...
Also, can i damage the rear defroster lines if i remove them improperly?
Thanks in advance
Old Mar 17, 2005 | 11:13 AM
bigsherv's Avatar
i have never heard of shop charging to remove tint. Call around and see if a place will do it for free.
Old Mar 17, 2005 | 11:15 AM
Teufelhunden's Avatar
hmm, im not a tint master, but yeah soap and water does help, and i dont think soap and water is going to ruin your interior, if thats what they use to put them on, then you prob already had them dripped on your trim, from previous install. as far as the rear, the defroster lines do get messed up if not removed properly. just try the soap water thing on the back and remove slowly and very little to see if the lines come off or not.
Old Mar 17, 2005 | 11:22 AM
takkar's Avatar
Ottawa ( Canada) is a small place...so everything costs money here...installation was $200 and remova of old tint is roughly $125!!! The guy says its a 2 hour job ( so that means they make 60+ dollars an hour)!!!
Old Mar 17, 2005 | 11:24 AM
takkar's Avatar
Another question: when the window is up...how far below the bottom of the window does the tint go to..in other words..do i have to remove the trim to remove the whole tint?
Old Mar 17, 2005 | 05:21 PM
ThunderMaxi's Avatar
My tint is so light that I want to re-do it also. So, will a little yanking and soap and water do it??? I want tint that was as dark as my last Maxima.
Old Mar 17, 2005 | 05:22 PM
Anyone know a how-to or a write up for this? I am getting a late night idea... after The Apprentice, of course.
Old Mar 17, 2005 | 05:27 PM
NisMoN00B's Avatar
+Cru OG
I used soap and water, a plastic spatula (to scrape the tint) and towels to keep the water from dripping into the trim.
Old Mar 17, 2005 | 05:32 PM
MaximaGirl
I had to remove mine off the front windows to comply with State law and I did it myself with a bottle (the whole bottle) of windex and a razor blade, the razor blade was to get the glue gunk that was left behind. I didn't do the back window though.
Old Mar 17, 2005 | 05:42 PM
ZIPPIN's Avatar
Mauja He Mauja
i used razor blades and 0000 steel wool, with eagle glass cleaner. the rear was a little harder, cause you don't want to mess with the defogger. take extra care with the rear and it will be fine. i have read that a steamer works wonders, but i did not have access to one. that's why i did it the old fashion way. i used the blades in between the defogger lines, and used the wool with lots of eagle, no problems other than my back pain
Old Mar 17, 2005 | 06:08 PM
takkar's Avatar
thanks guys..
Thanks for the steam cleaner idea ZIPPIN..will try that out and let you know...
Old Mar 17, 2005 | 06:11 PM
I will have to try this.
Old Mar 18, 2005 | 03:21 AM
EastSideMaxima's Avatar
A swift Bimmer driver
how about using a hair dryer or a heating gun and then removing it?
Old Mar 18, 2005 | 03:58 AM
handsofstone's Avatar
to do the back indow. you have a couple options. you can use a wheel acid, but you must work fast and in very small area's and you have to be real careful. or wait until it gets a little warmer outside. take a black trash bag, cut it to the exact shape of your window. then take a spray bottle and spray the tint. put the trash bag over the tint and roll up all of your windows. make sure youre parked in the sun. after a couple of hours the tint and glue will peel right off.
Old Mar 18, 2005 | 05:04 AM
ZIPPIN's Avatar
Mauja He Mauja
i tried that and it made the glue more nasty and sticky. spraying amonia, covering the window with a trash bag works. i did not do it that way due to the smell of amonia..
Old Mar 18, 2005 | 05:06 AM
Ammi's Avatar
350 Detroit Muscle
amonia and heat gun/hot weather works
Old Mar 18, 2005 | 09:31 AM
Redstone's Avatar
Actually most shops do charge to remove window tint. It takes quite a while to remove it too from my experiece. The best thing to use to remove window tint is adhesive softener. First use a razor and start stripping in the corner of the window and as you peel the tint away slowly spray the adhesive softner between the tint and the glass and wait a minute or two to allow it to soften and it should peel more easily. It also helps to clean up any residue of adhesive on the windows after the tint has been removed completely. You can buy adhesive softener at Wal-Mart in the auto section.
Old Mar 18, 2005 | 09:57 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I have done this before .. for the sides use Soap and water...... and a Blade, don't worry about the water getting into the door no harm done..... in the rear well, the deffoger will get damaged if you are not careful, use a hair dryer and pull from the cornes a bit at a time....
good luck
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
