grinding from the front brakes... what's wrong?
Old Mar 17, 2005 | 04:07 PM
al7601's Avatar
I've been noticing a grinding noise coming from the front wheels after say a 30 minute drive. The pads are new.
What could it be? Has anyone else had the same problem?
Old Mar 17, 2005 | 04:11 PM
southernrednik
warped rotors
Old Mar 17, 2005 | 04:17 PM
al7601's Avatar
is that a definite? Is there any thing else it could be?
Old Mar 17, 2005 | 04:20 PM
southernrednik
no, but your brakes consist of rotors and pads. the caliper and brake line IMO would not cause this problem. plus, any 5th gen max is know to warp rotors...
2K3MAX2NV's Avatar
"tse-tse fly"
most likely its warped rotors.... ive got 35k and mine just became warped so i picked up powerslot rotors with hawk pads which Im installing this weekend
Old Mar 17, 2005 | 04:39 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
If you have oem replace your rotors with All good POWERSLOTS AND HAWK brakes... and problem solved....
Old Mar 17, 2005 | 04:54 PM
al7601's Avatar
any suggestions on where to get a good deal on them from?
Old Mar 19, 2005 | 07:04 AM
MikeD95SE's Avatar
Whats up bro, I am in the process of ordering some powerslots right now and was doing some research here... I just checked www.sportcompactonly.com and they are 156.98 for the fronts right now which seems really cheap to me. I think they are 199 on www.custommaxima.com...
Mike
Old Mar 19, 2005 | 09:37 AM
spiromax's Avatar
Seoul Man
If it's warped rotors, then you should be getting more than just a grinding sound. You should also be feeling a strange shudder/shake/shimmy when you use the brakes, especially when you're trying to slow down from high speed.
Old Mar 19, 2005 | 09:43 AM
upstatemax's Avatar
i agree... your brakes would feel like a** on the highway. if you are not getting a vibration i am going to say that the rotors are not warped.
i would say to replace the pads and rotors at the same time anyway.... i will be going with powerslot myself...
Old Mar 19, 2005 | 09:51 AM
adithius's Avatar
If your not feeling vibration, and shimmy from your steering, then you dont have warped rotors. I am aware that the 5th gen has the warping problem but I dont think this is the case here. Check your pads first, see if they are worn to the metal. Do you see any pitting or irregular rotor wear. If you do then you have messed up your rotors, and need to change them.
You might also want to try and see if you have any thing stuck in between the dust shield. That might be causing the problem.
Old Mar 19, 2005 | 10:46 AM
al7601's Avatar
thanks for all the feedback. I don't have any vibration from the brakes so it may not be warped then. As far as the pads go, I just installed new Bosch pads, again in the front, a couple months ago. I am going to check if there is anything stuck in the dust shield.
What is it exactly that I'm looking for when trying to see any pitting or irregular rotor wear?
Old Mar 19, 2005 | 01:23 PM
2K3MAX2NV's Avatar
"tse-tse fly"
i just did my install on the front brakes powerslot rotors and hawk pads and the combo is great!!
Old Mar 19, 2005 | 01:35 PM
Stardust's Avatar
F---ing Kangaroos
Try putting some of that "disk brake quiet" lube stuff on the backs of the pads.
Old Mar 19, 2005 | 03:25 PM
TEEdotMAX's Avatar
there's a metal shield behind the rotor that might be causing the noise. i noticed a similar noise on my max after changing the rotors... i simply bent the shield away from the rotor to give it some more clearance & problem was solved.
also make sure the rotor is flush w/ the hub... make sure no debris or spaces between the hub & rotor
Old Mar 19, 2005 | 07:56 PM
adithius's Avatar
What is it exactly that I'm looking for when trying to see any pitting or irregular rotor wear?[/QUOTE]
If it doesnt seem smooth, cracks.
It should be smooth.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
