E-brake
Old Mar 30, 2005 | 06:39 PM
max929's Avatar
E-brake
Has anyone had an issue with the e-brake sticking??? I sometimes hear a light humming sound while driving a higher speeds. When I stop to check it out, I pick up a burning smell coming from the rear passanger side wheel. Just wondering if this is a documented problem or just mine
Old Mar 30, 2005 | 06:58 PM
irish44j's Avatar
retired moderator
probably not the ebrake sticking, it's probably a frozen caliper piston....it's been known to happen (on all types of cars)....requires a caliper rebuild or a new caliper (which is probably cheaper)........
Old Mar 30, 2005 | 07:06 PM
max929's Avatar
Thanks Irish. If I take the wheel off, is there any tell-tale signs of a frozen caliper??
Old Mar 30, 2005 | 07:30 PM
irish44j's Avatar
retired moderator
visually, probably not.....but if your ebrake cable isn't stuck (unlikely it is), the only other thing that it couldbe is a frozen caliper.....drive around for a while and then see if one of the calipers is "hotter" than the others (this will involve touching the caliper, so do it quick so as not to get burned!)
irish44j's Avatar
retired moderator
if you figure out which caliper is bad, look in the FS forums, someone is selling some used rear calipers for dirt cheap!
Old Mar 30, 2005 | 08:14 PM
max929's Avatar
Thanks Irish, I appreciate the info. Crap!! I better finish this term paper soon, I have class in 9hrs.
Lowered_a33
Aug 24, 2015 04:35 AM
Adambrown_2001
Feb 27, 2002 01:41 PM
buckwilly4
Sep 20, 2001 02:37 PM
Max2000
Nov 24, 2000 05:56 AM
PiotrC70
Nov 17, 2000 08:06 PM
