Feeling a loss of power...
Old Apr 17, 2005 | 08:39 PM
SE01's Avatar
I usually don't beat my Maxima nor speed excessivly on the highway. Today some ****-wipe was going slow so I decided to throw it in 3rd on the highway and take off to pass him. Maybe it's just me, but it felt like I had no top end power at all. From 4,500 RPM's to redline, it just didn't feel like it used to. I got it with 36,000 and it just turned 60,000, and maintained very well. The only "mod", if you would call it a mod, that I have is a Berk Intake with just the cone filter, no chrome pipe. Any ideas? Do you think it's just me or does my Maxima have a problem?
Old Apr 17, 2005 | 08:40 PM
S00NR1's Avatar
OU > *
I would say it sounds like your VIAS is gone.....you should do a search for the VIAS fix and take a look at it.
Old Apr 17, 2005 | 09:31 PM
2KBluePearlMax's Avatar
Hey Just a thought but maybe your Maf is done for. Do you still have the original Maf on there?
Old Apr 17, 2005 | 11:13 PM
lalaMAX's Avatar
did u hear a louder sound when the RPM went past 5000? if u did the Vias should be fine.... if it sound climbing constantly... then maybe your vias need a JB wield....
because you should be able to hear when the Vale is open....
Old Apr 18, 2005 | 09:49 AM
go-max's Avatar
Or you can pop the hood and manually rev it beyond 5,000 @ the Throttle body and watch for the brass arm under the intake to move. I don't seem to notice much noise difference in mine when it kicks in especially compared to the way my previous Taurus SHO kicked in @ 4K.
Old Apr 18, 2005 | 10:11 AM
bitar_19's Avatar
I had that problem it was my maf I had it replaced and now it runs good.
Old Apr 18, 2005 | 02:42 PM
SE01's Avatar
I honestly didn't even notice, maybe I will try today.
Old Apr 18, 2005 | 02:50 PM
99 SE-L
well i have random power loss sometimes it pulls like a monster after 40 but then it pulls like my grandfather 95 4 cyl camry... what is vias and what are the symptoms of al malfunctioning one
Old Apr 18, 2005 | 03:42 PM
max929's Avatar
This will explain
http://www.cardomain.com/memberpage/763858/5
Old Apr 19, 2005 | 05:26 PM
rkcolo's Avatar
I am experencing the described loss of power, car runs out of power above 4K and is pretty much done at 5K, runs great at below 4K. Just took the VIAS out and it appears to be fine and solid to the shaft. What next? I guess I can put it back together and try to chek movement of the soleniod at 5K rpm. Is there a check for the MAF? Any other ideas?
TallTom
57
Oct 14, 2025 05:16 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
zmcneely13
Sep 26, 2015 02:26 PM
