HOW-TO: Perfectly cover-up trunk holes after debadging. ***PICS***
Old Apr 18, 2005 | 04:03 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Ok, so I finally decided to fully debadge the max, which went fairly well...until I removed the NISSAN hamburger. There are two mounting holes in the trunk which need to be filled once it is removed, and here is how it was done...
This image shows what is left one the hamburger is gone
Start by taping up the outside of the holes using painters tape. Make sure you prep the surface with alchohol to ensure proper tape adhesion.
Next, mix up a small glob of bondo. You can get this stuff at Advance for $15/gallon.
Old Apr 18, 2005 | 04:07 PM
YOU WILL ONLY HAVE A WORKING TIME OF 4 MINUTES!!! So get ready. Put some rubber gloves on an push some globs of bondo over the holes. Do this by applying the bondo through the rear of the trunk...it is quite easy to get to. Allow to cure for 30 minutes,
Remove the tape. It should look like this...
Old Apr 18, 2005 | 04:08 PM
I purchased some touch-up paint from Cherry Hill Nissan. Simply apply a small amount over the holes, and you're done!!!!
Old Apr 18, 2005 | 04:23 PM
nyautostyle's Avatar
sweet, do u have better day pictures of the results? cant really tell how it looks complete.
** Post 1000 ** oh yeah baby..
Old Apr 18, 2005 | 04:33 PM
Yeah, I will have some up in a little bit!!!
Old Apr 18, 2005 | 04:58 PM
roll4life's Avatar
did the same thing to my car
Old Apr 18, 2005 | 06:53 PM
03on18s's Avatar
that looks awesome!!! i'm def doing that soon..
Old Apr 18, 2005 | 06:59 PM
NYPD-Arnold's Avatar
Z
Fantastic job, dude.
Old Apr 18, 2005 | 07:05 PM
Deckdout2's Avatar
Play with my balls
That does look really good, I must say.
Old Apr 18, 2005 | 07:37 PM
Kevin's Avatar
pretty good, i would never have thought you cna get that bondo stuff at advance.
Old Apr 18, 2005 | 07:54 PM
Ammi's Avatar
350 Detroit Muscle
that does look nice and clean
Old Apr 18, 2005 | 08:24 PM
jesse's Avatar
VTEC This!
nicely done, and damn good idea!
Old Apr 18, 2005 | 08:31 PM
Lytheum's Avatar
ive been tossing around the thought of debadging. anyone have pics of a 00 or 01 gxe/gle with out badges?
Old Apr 18, 2005 | 08:47 PM
lex3015's Avatar
very nice, when i debadge i left that on because of the grommet holes, looks like i know how to solve that problem. thanks alot!
Old Apr 18, 2005 | 09:14 PM
2kayznmaxima's Avatar
nice job metal!
Old Apr 18, 2005 | 10:21 PM
Teufelhunden's Avatar
whats up with these write ups metal? good job though man. maybe ill do mine, i dont know how that'll look on a white max.
Old Apr 18, 2005 | 10:47 PM
Maxi113's Avatar
The spot from the emblem can still be seen, hopefully that'll go away after some washes! Looks good
Old Apr 18, 2005 | 11:30 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Over time, the paint and the bondo will flake off. Proper prepping of the area would have been to sand/grind off paint in the area where you apply the bondo.
Old Apr 19, 2005 | 07:56 PM
Metal, Did u get a chance to take pictures in the day yet?
Old Apr 19, 2005 | 07:59 PM
SEmy2K2go's Avatar
Go BUCKS!!!
^^ so your saying you would sand it before u bondo it? sorry im slow this week, ive been sick with the flu.
Yes, that's the proper steps to take in prepping any metal surface when you use the Bondo products. Their site actually suggests using a small piece of fiber paper as well to strengthen the area.
Edit: Here's a link with some detailed instructions.
Old Apr 19, 2005 | 08:03 PM
That's good to know, thanks for the advice.
Old Apr 20, 2005 | 06:10 AM
2K3MAX2NV's Avatar
"tse-tse fly"
u post *****
Looks great with the bondo!!
Old Nov 3, 2006 | 07:51 AM
paulfromchicago's Avatar
will this process work to fill up the holes on the front bumper left by a license plate? if so, i have another question - the holes each have bits of drilled plastic from the bumper sticking out. before applying the tape, i'd need to even out the bumper. do i just use sandpaper?
Old Jan 25, 2007 | 09:41 AM
eK9aT10pSi's Avatar
metal maxima - how is it holding up after some time now?
Old Feb 16, 2007 | 08:28 AM
JOE01's Avatar
I Would Suggest Welding In The Wholes Bond Will Eventally Wear Out And Crack. Weld Then Gring Then Paint.
Old Feb 16, 2007 | 09:26 AM
MaxBoost925's Avatar
Drug Money
My trunk didn't come with holes
but i like the work. kudos!
Old Feb 16, 2007 | 11:11 AM
GBAUER's Avatar
Seemy2k2go is right about the bondo thing. I'd give it 3-6 months before the bondo falls off the back. You have to prep it propery first or find something better than a flat surface to attach the bondo to. JB Weld may have been a better choice for this. Just a thought.
REDinLV
Aug 15, 2024 12:30 AM
chisam14
Nov 6, 2018 08:56 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
