HELP! Can't remove headunit from frame...(pics inside)
Old Apr 26, 2005 | 12:52 PM
NYPD-Arnold's Avatar
Z
I am having the worst f-ing luck in the world with removing my OEM headunit. The screws highlighted in red WILL NOT screw a damn's worth. I've put every ounce of strength into it, but it's no use. I've soaked the screws in some WD-40...nothing. WTF is the problem!? This is, literally, driving me nuts. I've posted this here and in the audio forum, because I need as many replies as possible...otherwise, I'm putting everything back together and just saying f*ck it. I just can't get the OEM out of the frame. =(
These are the culprits:
Old Apr 26, 2005 | 12:55 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Get a ratchet with a long handle and turn the screws...the longer the handle, the more torque you will have. Have 1 person hold the ratchet in-line with the screw, then turn the ratchet...it this does not work at firts, insert a hollow pipe around the ratchet body giving you a longer ratchet...the longer the handle the more torque you will have.
That is how I did it.
Old Apr 26, 2005 | 01:48 PM
MyownNismo's Avatar
Future Camaro SS owner
I had no trouble with mine and I just used a drill. Get yourself a P2 phillips bit if you don't have one.
Old Apr 26, 2005 | 01:50 PM
MyownNismo's Avatar
Also I just thought of this. If you strip it out just go to sears where they have a bit the cuts the top off the screw.
Old Apr 26, 2005 | 02:02 PM
The screws are recessed, would they still be able to do that?
Old Apr 26, 2005 | 02:03 PM
ChromeSE5's Avatar
i laid that piece on the floor and used my weight and drill to remove the screws. I was having trouble also but once i did that, it worked.
Old Apr 26, 2005 | 02:05 PM
Smokie5s01's Avatar
tighten the screws and then back them off.....I went through the same process and this is how I got them off.....
Old Apr 26, 2005 | 02:09 PM
MyownNismo's Avatar
It's called a extractor.
Old Apr 26, 2005 | 02:11 PM
99 SE-L
Oh, man did i have trouble doing that we tried everythign then i stripped it and then i attempted to drill it out, so it got me pissed so i just cut the ears off
Old Apr 26, 2005 | 02:12 PM
brettb's Avatar
O'rly
This is exactly what I had to do. You need to use a high powered drill and had someone hold on to it as I punished that damn thing.
Old Apr 26, 2005 | 02:32 PM
Z
I got em out. Went to my mechanics and the two of them managed to screw them out. Now I'm faced with a new f*cking problem...CD Error FO. The headunit won't open up to take in a CD.
What does CD Error FO mean?
Old Apr 26, 2005 | 03:57 PM
Z
CD slide won't open. I disconnected the HU and will be putting the old one back in tomorrow. The f*cking screws are once again stuck to the frame, and they weren't even fastened tightly when put back on. *sigh*
Old Apr 26, 2005 | 04:00 PM
LithiuMax
Check your PM's.
Old Apr 26, 2005 | 04:06 PM
jzwu's Avatar
I have to say Nissan's got some weird stuff . My stock HU had exactly the same problem when I tried to install an Alpine HU.
A strong metal drill with (lots of) sweat did the trick.
Old Apr 26, 2005 | 04:07 PM
Z
Thanks, again.
Old Apr 26, 2005 | 04:09 PM
LithiuMax
Originally Posted by NYPD-Arnold
Thanks, again.
By the way, when I was replacing the headunit in question, I had to go to a shop to have them remove those bolts as well. They were impossible to move by hand, and stripped 2 of my screwdrivers.
Old Apr 26, 2005 | 04:15 PM
Z
Yeah, ****'s insane. But they're stuck again, weren't even tightened up at all. So weird...
Old Apr 26, 2005 | 04:16 PM
Sammzway's Avatar
Yo Arnold bro, you tried man. I give you props for tryin to fit that 6 cd changer. But i'm sorry things had to turn out this way but.. all I have to say is..
Old Apr 26, 2005 | 04:26 PM
Z
Poor mouse...he looks so cute. =(
And Sam, I'm so kicking your ***. I'm gonna' T.P. your house, biotch!
Old Apr 26, 2005 | 05:34 PM
MoDiddy's Avatar
Hey, I had the exact same problem...couldnt get them off and i was getting sooo annoyed...so i just ordered new brackets...cost like 15 with shipping...not too bad
Old Apr 26, 2005 | 06:12 PM
Sammzway's Avatar
Old Apr 26, 2005 | 06:17 PM
Z
Hahaha. I hate you, man.
Old Apr 26, 2005 | 07:03 PM
shoman94's Avatar
Hey guys....just use an impact driver. Works slick.....
I'm talking the hand held one you use with a hammer.....
Old Apr 26, 2005 | 07:37 PM
TheBigDu's Avatar
I had the same problem taking out my stock HU. I broke two or three philips drivers before getting the screws out. I think what finally worked was sticking a nail into the center of the screw head and whacking it with a hammer a few times. This somehow broke the screws free enough to unscrew them. Still took a LOT of force, but they came out.
Old Apr 26, 2005 | 08:26 PM
MetaOrbit's Avatar
Got Projectors?
Damn guys. I just used an 18v cordless drill on the highest torque setting and put my weight into it. They came right out.
Old Apr 26, 2005 | 08:44 PM
Bensmax00's Avatar
thats bs man the longer the handle the more torque you will loose--I use a small screwdriver and if that dont work use a quarter in drive ratchet and a socket that fits a phillips bit and a small extension--those screws are a motha f*&ker--Ive even used an impact driver--a screw driver that u hit with a hammer--but only on defective units not rec for units that are going to be reused
Old Apr 26, 2005 | 10:04 PM
MaximaPolak's Avatar
I used this also.
Old Apr 26, 2005 | 10:08 PM
TheBigDu's Avatar
Torque = Force * Radius
(larger radius = more torque)
Old Apr 26, 2005 | 10:15 PM
Zaypka's Avatar
drill will help alot, thats what i used
Old Apr 27, 2005 | 12:45 AM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
have you tried liquid wrench? that may make it easier.
Old Apr 27, 2005 | 01:19 AM
HNDA ETR's Avatar
Still Here... IM me for more..
That's what I had to do...
Old Apr 27, 2005 | 04:34 AM
Morgan06's Avatar
Isn't that a girl's name?
true story. a longer extension loses torque, a larger radius adds torque.
my bolts were stuck too when i put in my ddx, i just drilled the stockers out.
The Frye
Sep 2, 2021 11:03 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Excalibur23
Oct 13, 2015 04:33 PM
Colossus
Sep 9, 2015 05:46 AM
lowpost99
Sep 8, 2015 05:06 AM
