My Tranny Dying?
Old Apr 29, 2005 | 10:19 PM
ZeRo MaX's Avatar
My Tranny Dying?
Well... I have an auto SE with 90k miles...
Here is the problem.... I just installed my intake.... and I noticed that my shifting is kinda slow...
When I press my feet on the gas to hit it... It would reach about 4k rpm... and suddenly slows down and goes up to almost 5k rpm and shifts... the speedo seems to go up so slowly... because it's stuck on first gear and keeps reving... until finnaly it hits 2nd gear and everything does the same until the 3rd gear but not as mad as the 1st gear....
I'm not sure if this is a tranny problem or MAF problem....
Here are somethings I am going to do to see if it's gonna get better...
-Change Oil
-Change Spark Plugs
-Add Fuel Injector Cleaner
-Check All Fluids
I hope it's not my tranny slowly dying :-(
Old Apr 29, 2005 | 10:21 PM
ZeRo MaX's Avatar
This of course only happens when I go WOT... when I cruise.. it's like a regular car drivin'...
Old Apr 29, 2005 | 10:23 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
MAF problem... callll Dave B 1-888-254-6060 and get a new one...
Old Apr 29, 2005 | 10:29 PM
ZeRo MaX's Avatar
How long do I have before MAF completey dies?
Old Apr 29, 2005 | 10:35 PM
Lontar1's Avatar
that's a good question ..... I also saw it at www.courtesyparts.com
but what you describe doesn't sound at all as a tranny issue.
Old Apr 29, 2005 | 11:09 PM
4evamax's Avatar
Adding Strength To Maf Issue
This Is A Maf Issue, You Don't Need Me To Tell You That You Had All These Other Guys Telling You The Same Thing But, My Question Is I Went To That Site That Was Posted Up To Buy The Maf.
I Want To Know If The Maf Is Something I Can Just Install My Self Or Do I Need Someone To Put It In Every Time?
I Mean Can I Play This By Ear Without The Computer Hookup?
What Horsepower Does That Maf Max Out On?
I Don't Want This To Happen Again To Me, My Mechanic Charged Me A Bunch Of Money To Fix That Maf Last Time.
Old Apr 30, 2005 | 04:02 AM
Lontar1's Avatar
If you do it yourself it will take you less than 20 minutes to install with your eyes closed. You will need a special bit to remove the screws
Old Apr 30, 2005 | 09:43 AM
Puppetmaster's Avatar
Is it anything similar to this? http://forums.maxima.org/showthread.php?t=341010
Could be your tranny....
Old Apr 30, 2005 | 05:12 PM
ZeRo MaX's Avatar
that seems like it as slow acceleration... for my.. it seems like the gear is sticky.. it won't shift till a while... and this ONLY happens when i go WOT.... i'm kinda ticked off... but for now i've been just goin' cruisin'.. no more WOT...
I need a tranny/maf expert...
Old Apr 30, 2005 | 06:45 PM
No, I'm pretty sure what he says is that when he stomps on the gas... rpms go up and the tranny hesitates before shifting, which sounds like what is happening to you. Unless I read the thread wrong. Anyways, I'm sure someone who has had the same problem should be able to help ya, so hopefully one of em will stumble across this thread. I had the same problem on my VW 3 years ago, but I traded it in for the Max before the tranny died...
Old Apr 30, 2005 | 07:09 PM
ZeRo MaX's Avatar
I don't want the tranny to die... nooooo
If it does... I guess I better start lookin for another one..
Will 02/03 transplate ok? :-D
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
maxima297
Sep 30, 2015 03:32 PM
pktaske
Sep 4, 2015 08:40 AM
