Throttle body
Old Apr 30, 2005 | 09:00 AM
NOCturnalI30's Avatar
Throttle body
Went to get my Advanced timing done and they said my throttle body is clogged. It took a while for the consult II to learn my idle air blah blah. So basically i need to clean it. Besides wiping it down with carb cleaner anything else i should do????
Old Apr 30, 2005 | 09:10 AM
SoonerFan's Avatar
Cletus
to completely clean it you need to actually remove it so you can clean the part behind the butterfly valve too. i have pics on my website to show you how.
http://www.cardomain.com/memberpage/335422/8
Old Apr 30, 2005 | 10:17 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I'm planning on doing this soon.. to my car.
Old Apr 30, 2005 | 10:19 AM
LA02MAX's Avatar
I'm too afraid to do it....i've heard horror stories about the after effects (although most aren't really proven to be caused from cleaning the TB)
Old Apr 30, 2005 | 11:40 AM
nicks79's Avatar
so did they advance it for you or not?
Old Apr 30, 2005 | 12:38 PM
PoLo's Avatar
2-Wheelin it...
the aftereffects is because the buttefly is electronically controlled, and when you move it to clean the grime around it, you throw it out of wack. suddenly you turn on your car and WTF?!?!??! why is my idle so damn idle. sucks to be you. AFAIK, you have to have a consult to do the Idle re-learn. now, a few tricks i've heard about lowering the idle, which were done on my car when they upped my timing, was to disconnect the MAF while the car is idling. this would force a lower idle, and then pop it back in. when i had my idle relearned, the idle wouldn't drop below 975rpm. finally he pulled the MAF, it dropped to 800, pushed it back in, then did the relearn, and it adjusted to 612/625.
so, what did you learn today. you can do a limited TB cleaning. just dont' touch the butterfly. if you do, be ready for a high idle. if you leave it alone, you're good. i guess you could always spray it with TB cleaner and let it soak. that would take care of SOME of the grim. but it's far from a thorough cleaning.
Old Apr 30, 2005 | 12:56 PM
Aaaaaaaaaahhhhhhhhhhhhhhhhh I Have High Idle Omggggg Wtf Do I Do Now
Old Apr 30, 2005 | 01:25 PM
PoLo's Avatar
2-Wheelin it...
well you do TRY the idle relearn and see if that works. i don't know the instructions but i know the technosquare website teaches you how to do the idle re-learn. although, from what my buddy told me and he owns a consult II so we did it the easy way, he says you can NOT do it via the other method (press gas, wait 10 seconds, etc...) but hey, it may work. try it. see what happens. if now, then you'll have to get a hold of a consult II and do the relearn. again, if they can't get that idle to drop, disconnect and reconnect the maf. that forces it to drop like 4-500 rpm.
Old Apr 30, 2005 | 01:32 PM
My car turns off if i disconnect the maf
Old Apr 30, 2005 | 01:46 PM
PoLo's Avatar
2-Wheelin it...
hmm...then i guess don't do that...although mine stayed on....or maybe he had the gas pressed when i unplugged the maf....i dotn' remember...it was awhile ago....
go to the technosquare site and look up the idle relearn instructions and try it...see what happens.
Old Apr 30, 2005 | 04:07 PM
scopium
everytime you clean your tb your timing advances 17 degrees i think
Old Apr 30, 2005 | 04:58 PM
nicks79's Avatar
And How did you come to this conclusion? If that was true, then no one had to beg stupid dealer to advance the timing.. But i think you are smart enough, and trying to pull a joke here. But if not.....
Old Apr 30, 2005 | 07:16 PM
BP's Avatar
BP
lol @ this thread.
Old Apr 30, 2005 | 07:24 PM
PoLo's Avatar
2-Wheelin it...
Originally Posted by BP_3.5
lol @ this thread.
? what's funny ?
Old Apr 30, 2005 | 07:46 PM
BP's Avatar
BP
seems like the blind leading the blind. there's been much dealer smoke blowing and tb fubars on this site. just seems like people should know better by now. and the tb cleaning advancing timing tops it off.
Old Apr 30, 2005 | 07:51 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if you do not understand what you are doing then leave it alone. i know everyone has to learn somewhere but geez.
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
