installing rear sway
Old May 2, 2005 | 05:29 PM
DJ2Max's Avatar
hi i have a question about step 6 in matts rsb write up.
Step 6. Tighten locknuts down to 25ft lbs of torque. If you do not have a torque wrench, tighten the locknuts until the bushing hardware bends into the base plates.
couldsomeone clarify what exactly the bushing harware and base plate is please? pics would be great.
Old May 3, 2005 | 07:26 AM
DJ2Max's Avatar
bump.... anyone?
Old May 3, 2005 | 08:06 AM
kcowden's Avatar
which part of the sway bar are you taking about? The section that attaches to the rear axle or the part that attches to the swing arm?
Old May 3, 2005 | 09:32 AM
DJ2Max's Avatar
im not sure thats why im asking. its step 6 in this write up
http://www.moodym.com/maxima/tech/addcorsb.html
Old May 3, 2005 | 10:49 AM
joebangaa's Avatar
i didn't torque anything installing the stillen rsb
Old May 3, 2005 | 10:56 AM
kcowden's Avatar
I didn't use a torque wrench either with no problem at all.... you'll know when it's tight. If you had a torque wrench, you'd be surprised how easy it is to get to 25ft. lbs. of torque. Just make them good and tight and don't try to strip them off the bolt and you'll be fine.
Old May 3, 2005 | 11:36 AM
DJ2Max's Avatar
thanks for theinfo. i still have no clue what the bushing hardware that he refers to is.
Old May 3, 2005 | 11:44 AM
Puppetmaster's Avatar
Have you tried asking Matt himself? Send him a PM or IM... he's online right now...
Old May 3, 2005 | 12:05 PM
DJ2Max's Avatar
whats his name?
Old May 3, 2005 | 12:20 PM
scopium
just tighten as hard as you can
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
