5spd Owners- NEW MOD review
Old 03-22-2006, 09:18 PM
  #121
SuperStasiu's Avatar
Muahahaha if they only knew muahaha muahahaha ahahahah ahahahaha omg i've gone insane
SuperStasiu is offline
Old 03-22-2006, 09:31 PM
  #122
drag racing is for wussies
BlackBIRDVQ's Avatar
Actually lemme work on the front tomorrow and I will let you have pictures of what I find out. I didn't have much time on my hands when working on that stuff last time, but since the boss is out for vacation starting tomorrow I will have a whole week with no one to tell me when to stop working :P I did show ya the pics on AIM of the stuff installed last time we talked bout my Volk wheels right ?
I might need a hook up of some sort on Eibach ERS springs, I wanna get rid of my JIC 9kg/6kg springs for something stiffer- especially for the rear. I also have an idea for the rear Panhard rod that we need to talk bout and I will take some pictures/photoshop it.
BlackBIRDVQ is offline
Old 03-23-2006, 07:30 AM
  #123
The Definitive AE Master
Larrio's Avatar
pictures and measurements would definitely get this project on the road!
I get all the ERS springs from importrp on the org.
Larrio is offline
Old 03-23-2006, 11:33 AM
  #124
young1976's Avatar
Interested
I'm interested, how do I get one? Lario, I PMed you.
young1976 is offline
Old 03-23-2006, 12:36 PM
  #125
Larrio's Avatar
I received an email from you. Already replied with information. Thank you
Larrio is offline
Old 03-23-2006, 03:57 PM
  #126
Larry, we need to talk on AIM. I got something to share with you that should improve the handling of our rear beam WAY more than any other mod you can think off.......
I will PM importrp- bout the ERS springs, I decided to ditch those JIC 9/6Kg springs in favor of something to my taste and needs. Looks like 3.5" springs with 8" height is normal for coilovers these days.
Old 03-23-2006, 07:40 PM
  #127
Larrio's Avatar
We'll have to wait for the weekend, this work week is killer
Larrio is offline
Old 03-24-2006, 09:14 AM
  #128
jedireland's Avatar
One can do this install without a problem, I've done mine in bout 15 min on a lift. I have no cat so removing the shields around the exhaust is a breeze- especially since they have been off quite a few times now.
When I replace the shifter bushing, do I need to remove the y-pipe (pre cats in there?). If this is the case, I want to replace the y-pipe with a performance one. Anyone seen a good thread with install directions? Also, I wouldn't mind a small increase in good, throaty noise. But, if there's a brand of y-pipe that is particularly loud or with an irritating note, I'd prefer to avoid that... ideas?
jedireland is offline
Old 03-24-2006, 09:23 AM
  #129
Larrio's Avatar
You should really check the link and picture I posted in page 4.
The shifter bushing is on top of the catalytic converter, covered by the heat shield. It is near the middle portion of the vehicle and not near the front where the y-pipe is.
Larrio is offline
Old 07-21-2006, 07:21 PM
  #130
swmtam's Avatar
I have a question.
Does this stop the shifter movement when the accelerator is pressed?
When I'm in 3rd or 5th, the shifter shifts back some when I step on the gas.
A few times, it has actually popped out of 5th. Will changing the bushing solve this or is there something else that I need to do to fix this problem?
I'm about to order one of the bushings regardless, but would like a little advice about what I'm experiencing with my shifter.
Thanks!
swmtam is offline
Old 07-22-2006, 11:40 AM
  #131
Merdan's Avatar
shifter movement
bushing won't hurt, thats for sure. It took the rubber like feel out of it. For it to pop out of gear you may have tranny wear problems. IMHO mod is well worth it from the Larrio. I think there's a group buy going on.
Merdan is offline
Old 07-23-2006, 02:20 PM
  #132
Chassis Freak
VQuick's Avatar
I was hoping the Energy Suspension motor mount inserts would fix the drivetrain slop that happens when you get on or off the gas in gear, but it didn't, and I doubt the shifter bushing would fix it since it has to be due to the engine moving in the bay and/or play in the drivetrain somewhere.
VQuick is offline
Old 10-24-2006, 06:11 PM
  #133
dgmaxse's Avatar
I installed the bushing with a Curtesy short shifter at the same time in January 2006. It was hard to shift (meaning certain gears, mostly 3rd and 5th, I would skip because the shifter would not go in that gear without forcing it in). Shifting would get easier when the car warmed up. This summer it was fine (warmer temps), but now it's getting cool again and I'm running into the same problem. It's worst when starting cold and outside temp is below 50 degrees. Does the polyurithane need to heat up? Is it the Curtesy short shifter? What can I do to fix this? I am using natural tranny fluid, will synthetic help?
dgmaxse is offline
Old 10-24-2006, 06:50 PM
  #134
ColdSHO's Avatar
its ur shifter. my pacesette was like that, just upgraded to a b&m much better. my pacesteer had rusted which made it hard to shift into certain gears.
i had my bushing installed at the same time, i find it much easier to find gears.
ColdSHO is offline
Old 10-24-2006, 06:51 PM
  #135
Chassis Freak
VQuick's Avatar
Get Redline MT-90 tranny fluid, it will help immensely. myoilshop.com if you can't buy it locally.
VQuick is offline
Old 10-25-2006, 05:17 AM
  #136
maseo77's Avatar
Did you do this install yourself? I have the bushing but I need a mechanic to install it because I have read that you must remove the cat to install it and my cat is welded in place.
maseo77 is offline
Old 10-25-2006, 02:38 PM
  #137
dgmaxse's Avatar
You don't have to remove the cat, though it is easier to get the old shifter out and new one in if you do. The cat bolts are rusted so much they are likely to break when you try to remove them. i broke one and gave up. I removed the heat sheild (above the cat) and worked around the cat. If you have a good tool set with a universal joint you should be OK though it will take longer
dgmaxse is offline
Old 10-25-2006, 02:39 PM
  #138
dgmaxse's Avatar
Thanks maybe I'll do the synthetic
dgmaxse is offline
Old 11-13-2006, 08:28 PM
  #139
gatmax97's Avatar
Larrio, is this mod still available? e-mail me the cost, and paypal address. My car is '01AE
gatmax97 is offline
Old 11-14-2006, 09:00 AM
  #140
Boss Chen Industries
Larrio Motors's Avatar
You'll have to check the GD forum, there is a waiting list
Larrio Motors is offline
Old 03-12-2007, 10:42 AM
  #141
96mAx2fast's Avatar
Why can't we just fill in the bushing area with a rubberized caulk ourselves??? Anyone ever think of that?
96mAx2fast is offline
Old 03-13-2007, 04:35 AM
  #142
young1976's Avatar
First, there are no voids on this bushing/bracket.
Second, Larrio takes the old rubber off and basically remolds the bracket with harder urethane... I think.
Third, rubberized caulk is just that. It won't do much. It's probably softer than oem bracket.
Old 04-05-2007, 10:35 AM
  #143
choppy718's Avatar
looking foward to doing this mod soon
choppy718 is offline
mclasser
22
11-12-2020 01:58 PM
ef9
10-04-2015 08:43 AM
REDinLV
09-28-2015 12:31 AM
rbaker100
09-25-2015 07:52 PM
Quick Reply: 5spd Owners- NEW MOD review
