Front suspension noise fixed
Old May 19, 2005 | 11:50 AM
Bucket's Avatar
Just a quick note about my recent wrenching.
I had a noise in the front left suspension that was evident going straight with small and large bumps. I read on another thread that a likely candidate was the strut bearing. I went and bought said item. Turns out that it's a piece of plastic. It is only a spacer. It does no friction duty at all. $21 for nothing.
The real culprit was the sway bar end link. I had checked the end links, but couldn't find any play in them. The left one was easy to manipulate/move by hand though.
Bottom line- For front suspension noise, check the sway bar end links first. If you can easily move them around on their pivots replace them. Strut bearings are a waste of time.
Hope anyone with similar problems helps-
P.S. Notice the easily searchable title. I think mods should come up with some kind of format for thread titles so searching would be a little less hit and miss.
Old May 20, 2005 | 09:12 AM
RY2KMax's Avatar
I've been trying to locate the front sway bar. I was looking for the ends and it isn't apparent. I have yet to lift the car. Is there a way I can locate the front bars without lifting the car?
Old May 20, 2005 | 09:24 AM
boondoxmax's Avatar
I started having that noise 6 months after i brought my 02 maxima and the dealer did exactly that....they replaced the sway bar bushings and the noise was gone.....the dealer told me that it's a common problem on the max that's why they knew what it was right away
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
official_style
Aug 29, 2015 10:10 AM
kirkhilles
Aug 8, 2015 10:53 AM
