fog light rewirin
Old May 21, 2005 | 07:57 PM
The Law's Avatar
I R The Law
fog light rewirin
i have a question i found the "how-to" on rewirin a fog light so it comes on by itself.....but i have a problem understandin this one part and i need some1 to explain this quote underneath
"9. Use quick splice to splice the fog wire you just stripped to the taillight wire (red with green stripe and silver spots):"
i dont understand that part
the site i got it from is http://www.innerbean.com/housecor/fog_rewire.html
help plz....cause im goin to do this soon
Old May 21, 2005 | 08:24 PM
bugbite77's Avatar
i just did this mod like 2 days ago on my 02 max. a quick splice is a thing you can use 2 hook up 2 wires without cutting one, the quick splice part is simple, cut the blue wire with silver spots coming out of the foglight relay, leaving more wire on the relay side than the wire coming out of the wire loom. then you take the end that is cut and put it into the side of the quick splice that only allows a cut wire to go into it, next put the red wire with a green stripe with silver spots in the side of the quick splice that allows the whole wire to go through it. then the quick splice has a metal clip in the middle of it that you press down that cuts the rubber on both wires and squeezes the bare metal on both wires, connecting both wires quickly, a.k.a. quick splice. u can buy these "quick splices" at radio shack, get the blue ones, they are the right size for the small wires you are spliceing. any q's lemme know. GOOD LUCK!!!!
Old May 22, 2005 | 06:52 AM
PO-POMAX2K's Avatar
I just did this Mod too. My only issue is that it negates the auto switch for the fog lights. Unless I did it wrong. Since the mod I've left my fogs on (2) times already but Damn it looks cool.
Old May 22, 2005 | 07:35 AM
bugbite77's Avatar
i dont understand what you mean?
Old May 22, 2005 | 07:40 AM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
I would say that you did it wrong. My fogs go off with the parking lights. Thats the way the 2002 rewire it supposed to work. On with Parking lights but still off with High Beams. The "AUTO" switch is for all lights including headlights.
Old May 22, 2005 | 09:35 AM
PO-POMAX2K's Avatar
I have a 2000, and maybe I did splice into the wrong wire. My fogs can now be turned on without the car running. Anyone w/ a 00-01 that can offer some insight? i used HOUSECORS write up for the install and followed the diections for the 00-01's. I agree w/ you that the AUTO switch should still work.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
