2 hot new HID projector retrofits
Old Jun 4, 2005 | 11:42 AM
Dr. Roy's Avatar
Since not everyone likes the look of the ebay projector headlights, i picked up some 00-01 headlights to fool araound with. these are not finished yet both still need some work, and unfortunatly i only have enough parts to make 1 of each, but now that i got them almost finished and they look good i will get my hands the parts needed to finsh these up.
hella rs6 bixenon
bosch golf/jetta d2s projectors w/ seperate H7 Hi beam reflector
Old Jun 4, 2005 | 11:56 AM
dominican254's Avatar
wow roy i thought bout doing this with my lights but didn't have the ***** or the money to do it. Looks nice, clean and now we won't hear people talk **** bout the ebay projector being ugly although i personally like em. Do you got any pics of em lit up?
Old Jun 4, 2005 | 11:57 AM
Dr. Roy's Avatar
I was also thinking of doing LED park/turn signals for these, but put them off to the side and maybee try and fit either bosh H3 foglight projectors,or a set optilux projectors in where the bulb sits, for acessory driving lights, but that might a little to much work b/c a potion of the lens would need to be sanded smooth.
the flat chrome part , (to right in 1st pic, down in second pic) that is on the side of car, is where the leds would go, od the auxilary prjector would sit in the depressin of the turn/park reflector
these are the projetors i was thinking of using
or
Old Jun 4, 2005 | 12:03 PM
Dr. Roy's Avatar
some indoor pics, from about 15 ft
the rs6 is a nice projector, it fukcing big, 3" dia. lens and nice color
low beam.............................................. ......................hi beam
the golf has a similar output to the E46's but has a strange little lever on the side of it so the cuttoff can be switched from ECE to straight
the golf pojectors lever - switched to flat cuttoff, moving it down gives the ece pattern
Old Jun 4, 2005 | 12:20 PM
i heard you did the e46 retro on your ebay lights im in the process of doing it. i got the projectors and have already mounted one. All im lokking for now is those damn bulbs and the ballast. Wasn't as hard as i thought so am glad im doing it myself. I gaot some pics on my homepage so you can see some pics. Leave any tips if am doing something wrong.
Old Jun 4, 2005 | 01:19 PM
HKMax's Avatar
Oh boy, Dr. Roy. Nice work! You seem to be a very adventurous man. And you are quite skillfull. I am digging the RS6 bi-xenon one. Can't wait to see finished product
Old Jun 4, 2005 | 04:04 PM
Kevlo911's Avatar
Kevlo for President
Nice its about time 00-01 start getting Bixenon projectors.
Old Jun 5, 2005 | 04:13 AM
808MAX-SPEC's Avatar
Great job Dr. Roy! You have out done yourself again.
Old Jun 5, 2005 | 05:51 AM
Yaco_Max's Avatar
WOW...DR.Roy
Very very good ......I mean Great job......
I can' t wait to see all this proyect done...
Old Jun 5, 2005 | 07:24 AM
ibag8rfan's Avatar
Awesome.. Might have to try this myself sometime
Old Jun 5, 2005 | 07:44 AM
Ammi's Avatar
350 Detroit Muscle
Awesome man
Old Jun 5, 2005 | 08:01 AM
upstatemax's Avatar
you dont happen to have pics of the install on the 00' headlights do you?? I have been pondering this for awhile and just dont have the ***** to wing it.
Old Jun 5, 2005 | 10:54 AM
makavelisk's Avatar
Damn doc......looking good.
Old Jun 5, 2005 | 06:08 PM
xtantmaxima's Avatar
great job as always, almost wish I had heard about this before sending the ebays to you. These are way more stealth and probably not as easy for a thief to spot.
Old Jun 5, 2005 | 06:30 PM
Wow...you proved just how easy it is to retro these projectors. Great job! I think you should have put in a bezel just so that it look aligned. Anyway, that just my opinion, but great job!
Old Jun 5, 2005 | 06:31 PM
LA02MAX's Avatar
damn, you have some skills with fabricating new light housings....that install looks so clean, it looks like it should have came that way from the factory! great job on these ones (as well as all your previous 'inventions' ) and keep up the good work!
Old Jun 5, 2005 | 09:10 PM
jesse's Avatar
VTEC This!
looks great man, real nice job, very clean! i love the second one with seperate H7 Hi beam. you gonna show them over at hidplanet? they'll love it
Old Jun 5, 2005 | 11:22 PM
Dr. Roy's Avatar
thanks...the feed back is appreciated and i am glad to see they went over well
When i get these finished up i will post some better pics, they weren't very photogenic when i took those, the pics were either bleached by the reflected flash or grainy and blurry b/c of low light, then my batteries died and these got put to the side.
these are extra lights i picked up, to see what is involved for a oem 00-01 retro, b/c i have had quite a few members ask. the rs6's are about done they need a shroud to hide the reflection of the projector, its hard to see b/c the pics are crap but the copper wire of the bixenon solenoid is reflected below and to the right. I got the stuff to make a shroud so everything gets tucked away nice and clean, I am pretty sure the rs6 have a buyer but that not a definite as of yet.
the golf w/ h7 hi beam still needs more work to get everything to fit inside the housing and work properly. Function follows form when making these up......I knew what i wanted them to look like, got everything so it looked good then got to work making it fit and adjust correctly. its a PITA and an odd combo of parts i need to get my hands to complete the second one, so it may be while before they gets finished. When they are finished, probably going to be a one of a kind set. b/c the parts contributing to the come from headlights that are a bit scarce and they require a lot of work to put together. so the cost of making up more sets would be prohibitive. But the pic does not do it justice, it looks real sweet up close. i really like look of that 1 1/4 " lens swimming in all that chrome,would definatly get a second, third and forth look from someone who knows the maxima, those who don't would look right over em b/c they look OEM.
when they are finally done they are going need a good home but cost more than my other retro's,
Old Jun 5, 2005 | 11:29 PM
lex3015's Avatar
very very impressed!!! excellent work. since this is a lights thread ill ask this question... the used dealership i do wholesale for has a set of 02-03 headlights that are missing the hid bulbs and ballast but otherwise ive got the whole oem housing. what would be the best/cheapest way to go about finding the right bulb/ballast set up for the lights? ive just getting an HID kit is the answer then id just throw it on my headlights i have in there now. thanx in advance
Old Jun 6, 2005 | 12:37 AM
ChromeSE5's Avatar
any set of ballast would do... you would just have to splice up some wires and what not... you might have to PM someone who has done the direct h4 to OEM HID replacement. Any BOSCH, PHILIPS, DENSO, or Matsu****a Ballast on ebay that use d2r is fine and some philips or sram d2r bulbs will work.
Old Jun 6, 2005 | 01:09 PM
amomaxima's Avatar
this is a question for Dr.Roy but i think itmay benefit all. On the HIDPLANET site they have a complete kit for sale that includes the projector lamps the bulbs ballasts...I am so interested in the retro but i am very nervous about doing the project my self. But would any of these kits be a good buy for our application. How good are the lamps, bulbs, ballasts, etc.
http://www.hidplanet.com/package.html
Old Jun 6, 2005 | 04:45 PM
irish44j's Avatar
retired moderator
Very impressive Dr.Roy...I really like the setup of the second one, although they both remind me of "terminator" for some reason Once again, you have shown that you are th undisputed master of headlight mods.
Old Aug 18, 2005 | 06:12 PM
Pri63's Avatar
any updates...I want to keep my 00 lights and projector them then install hid's...if of courses it's possible
Old Aug 18, 2005 | 07:29 PM
bremner44's Avatar
Holy gees! Look at that box of Maxima headlights! So you're the one with the crow-bar driving up our insurance prices. Watch out for those data dots. j/k
Looks good. I wish I had the ***** to take apart my lights, and the brains to modify them, and the money to buy the needed parts.
Old Aug 18, 2005 | 08:19 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Have you thought bout putting in the 02-up Q45 machine gun style light into the 5th gen housing ? Alot of 350Z guys do this and it looks SICK. I tried doing that to my AE headlights but the Q headlights go for alot on Ebay due to the 350Z guys...argh. Looks great thou. I got some TSX projectors for sale.
Old Aug 18, 2005 | 09:00 PM
ChromeSE5's Avatar
they are huge and honestly not worth the money imo since the output isnt that great compared to other projectors. You are right though, they do look sick as hell and a lot of lexus gs guys use it and it fits perfectly.
Old Aug 18, 2005 | 09:08 PM
00MaxSE's Avatar
Pointy Elbows
Wow that looks good. Amazing work.
Old Aug 19, 2005 | 02:50 AM
wcasskicker's Avatar
Roy sure has lots of projectors at home!! Great job!!
Old Aug 19, 2005 | 07:45 AM
icelandmaxima's Avatar
Maxima Fanatic
Roy you are the retrofit guru!
Old Aug 19, 2005 | 09:11 AM
Maxrider24/7's Avatar
Doc....you are the man.......this will def be on my to do next list......thanks
Old Aug 19, 2005 | 11:48 AM
Woody's Avatar
I want to retro fit projectors in my 02 headlights, but also keep the factory hids. So just replacing the hi beams with a projector hid.
Old Aug 23, 2005 | 02:12 AM
Icondapython's Avatar
Dr. Roy, god damn your the best man... these headlights look so freakin awsome. I'm pretty sure all the 00-01 max owners are really happy about this as myself. Keep up the AWSOME work man. Props for you.
Old Aug 23, 2005 | 06:04 AM
ColdSHO's Avatar
shaving down the plastic to put projectors where the turn signal bulbs are would be a pain, but some projos mount right in, i had a set in my first retrofit it looked really nice but i didnt smooth out the bumps so it didnt project much light, i count find a place to make the lence smooth, if u know a place let me know i have to make my other non-max retrofitted lights sanded.
Old Aug 23, 2005 | 06:24 AM
DJ2Max's Avatar
hey does anyone have pics of the 350 or gs with the gun style projectors? i saw a pic where some guy put them into his fogs. i thought that was beautiful.
Old Aug 23, 2005 | 08:49 AM
StL I30's Avatar
The Dr. does it again. Quality.
Old Aug 23, 2005 | 09:26 AM
Iron Scimitar's Avatar
Tha Snatcher
"The Dr. Is In..."
New Custom Title
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Vistance
Sep 17, 2015 05:17 AM
