Cleaning MAF Sensor
Cleaning MAF Sensor
My MAF is going and I got to wait awhile for a new one to come in, but i really need my car. Would cleaning it with some kind a solution help temporarily?
If so what can I use to clean it?
nah, i remember someone saying that cleaning it with a solution or anything is not a magic cure for the MAF. If its gonna go, its gonna go. Suck it up and pay the $8x.xx from jerryrome nissan or daveb.
A-
A-
It threw a code. Light got reset...Car is still driveable locally in short distances. I really need my car and I'm waiting for one to come in...I'm getting a new one...But was just curious if there was a temp fix until my new one came in...
These MAFs can be cleaned. A lot of folks go out and drop $100 because the MAF "blew". I laugh.
Take a Q-tip and some isopropyl alcohol or electric parts cleaner. Remove the MAF from the intake with the star security tool. Gently wipe the filament looking piece (see all the dirt/grease on your Q-tip). Allow to dry and replace. It's that simple and may save you some dough.
Symptoms of a failing MAF
I just clocked 80K and wanted to know what are the symptoms of a failing MAF (no code has be registered though).
First, upshift and downshift at low speeds there is this "jerk". The throttle body, butterfly plate cleaned and throttle cable not tight!!!. There is also a loss of power during uphill acceleration recently. The tranny was flushed and for sure it is not a transmission issue.
I heard that the MAF sensor could be underperforming/not working without throwing a code.
I like the idea of cleaning the MAF but I wouldn't do it as I totally depend on this car to work. Any suggestions!!!
Originally Posted by Max_Vader_2K
I tried the cleaning methond and it worked for about a week and then it failed all together. I recommend to go ahead and buy a new one! Don't waist your time.
(I swear I won't buy another vehicle that is just introduced like the 2K max).
Depending on what chemical you used, you could have caused more damage. I don't follow the logic of spending $100 when you can fix it for free...well, the price of the q-tip and alcohol if it's not laying around.
And whats the harm? You have to remove the old one any way. It's right there.
This is most likely your MAF Sensor... I just finished having my MAFS replaced. It cost a little over $1000. Much of the cost was due to the additional software needed to reprogram the ECM, which was required to keep the warranty at the dealership. My problem started off as erratic shifting during acceleration... Very soon afterwards, the loss of power started. If your dealership does not require you to have the ECM reprogrammed, then simple have the MAFS replaced (someone suggested < $100)... Otherwise, I would suggest cleaning it with brake cleaner and a qtip. The same brake cleaner used to keep the brake dust from becoming airborne when changing you brake pads. The brake cleaner will not leave a residue. Make sure that it’s completely dry prior to reinstalling the MAFS. I've heard many people having success with using this method.
Originally Posted by S00NR1
$1000???? You got jobbed there buddy. A typical MAF replacement at a dealer should run no more than $500.
I'm not trying to be a smart @$$, but to save yourself a few $$$ in the future, check here first... Guys here helped me save a few $$$ so far... BTW, I have a spare MAF for sale...
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
