Window Motor
Old Jun 9, 2005 | 04:59 PM
nysemt1's Avatar
Window Motor
Anybody have any problem with there window motor on there 2k3??
Old Jun 9, 2005 | 06:01 PM
importuner
maxima's in general are not common to having window motor issues. what is your specific problem?
Old Jun 9, 2005 | 06:11 PM
nysemt1's Avatar
won't roll up!!!
Old Jun 9, 2005 | 08:40 PM
Bensmax00's Avatar
won't roll up!!![/QUOTE]
you probly got a bad switch--I know how to test it--but its hard to explain because I work on Nissans all day-so I got tools that yo probly wont have--but I'll try---you can take a DMM and set it to to voltage--but you have to remove the door panel to do this. disconnect the motor harness connector--will be a black 2 wire connector located near the window motor--once diconnected--take the harness side(not to the motor to the harness)--and check for voltage when you move the switch up or down(now it doesnt matter which way you have the leads--one way is up and another is down) see that seems like a lot of work for you but this only takes me like 5 mins, cuz I have a load test tool(light bulbs).
---oh yea if you read voltage one way but not the other, then you need a switch--if both ways a moter---
Old Jun 9, 2005 | 10:39 PM
importuner
it can either be your motor, regulator (stuck, jammed) or switch as described before. if it is the motor per-say you can try banging on the motor while holding the switch down. this usually activates the motor temporarily IF that's the problem. good luck...
Old Jun 10, 2005 | 08:10 AM
merovi's Avatar
i did the led mod and on the main control switch i guess i fried a certain connection(which i believe i did...i saw smoke once) and now my passenger window wont roll up. i bought a new motor and it wasn't till then i figured out the motor is fine. my window will roll but not down.
AaronL
Aug 8, 2020 10:31 AM
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
