5 gen engine coil replacement
Old Jun 13, 2005 | 06:38 PM
JustinMKN's Avatar
Anyone know where that How To is for how to replace engine coils on 5th gen maxima's? 3.0L. I've got a 2k maxima and I just went through my 2nd set of nissan dealership coils. Need to figure out how to swap them my self. I remember seeing a write up for 2002-2003. Would appreciate it.
(yea I tried searching tonight)
Old Jun 13, 2005 | 06:43 PM
LA02MAX's Avatar
sorry for my previous post, that was for a 3.5 here you go: http://forums.maxima.org/showthread....ght=spark+plug
post #7
Old Jun 14, 2005 | 04:45 AM
JustinMKN's Avatar
post #7
Anyone else have suggestions? That web page no longer works?
Thanks!
Old Jun 14, 2005 | 10:49 AM
craigomax's Avatar
The coil change is very easy. I would recommend using a magnetic rod to remove the rear coil bolts as it is easy to drop them. I have a word file that has instructions for MAF & coil replacement (I pulled it from somewhere in this site) in the past. If you still need it, email me.
Old Jun 14, 2005 | 10:57 AM
CCS2k1Max's Avatar
Got an owners manual? It's in the Do-it-Yourself Section (8 IIRC) under "Changing Spark Plugs".
Old Jun 14, 2005 | 11:15 AM
E55AMG2's Avatar
Wat
Its not difficult to do. You need to remove the bolts that hold the coils in, remove the coils, then remove the plugs. Replace the plugs and reassemble everything
Old Jun 14, 2005 | 11:35 AM
JustinMKN's Avatar
Can you send me the Document? JustinMKN@hotmail.com
I cant PM you because your new or something.
Thanks Craigomax
JRod28
Feb 4, 2016 11:07 AM
kenc15
Sep 25, 2015 06:38 AM
Balkins
Aug 12, 2015 06:39 AM
maxima297
Aug 3, 2015 12:50 PM
