Window washer not working, any suggestions?
Old Jul 5, 2005 | 08:13 AM
jasba's Avatar
Just noticed yesterday that my windshield washer does not work. I added fluid, still nothing squirting out. I checked the fuses under the dash, and the one next to the battery box marked " window deicer", all fuses good. Any idea where to start my trouble shooting, a quick peek before work and I do not even know where the washer pump is.......
Old Jul 5, 2005 | 09:02 AM
njmodi's Avatar
Do I get a tax break?
Pump should be on the left side of the engine bay near the firewall - i.e. passenger side firewall.
Old Jul 5, 2005 | 10:04 AM
Zog's Avatar
Zog
Did you install a FSTB recently? Sometimes the line gets crimped by the bar. Also you could check the line and make sure there's not a blockage or crimp in the line.
Old Jul 5, 2005 | 08:37 PM
jasba's Avatar
Looks like I may have blockage in the line or spray nozzles. I kept playing with it while driving to work today, and finally one of the nozzles on the passenger side started spraying fluid. The other 3 are not working yet, but by the pressure I am getting from the one nozzle, I'm guessing that the pump is good. I will pull the lines an soak the nozzles in some CLR or something to clean them out. Thanks for the advise, hopefully that will cure it.
Old Jul 6, 2005 | 04:18 AM
Bluesbrekr's Avatar
Doctorate in Detailing
You can also use a pin to open th nozzles. Have you waxed the car recently? It just takes a little wax to block the holes.
Old Jul 6, 2005 | 07:29 AM
2k1Maxdrvr's Avatar
Yeah what he said!
Old Dec 16, 2011 | 12:29 AM
R12v56k 5th Gen SE's Avatar
Doesn anyone know eactly were the pump is
Old Dec 16, 2011 | 09:57 AM
Montego Murph's Avatar
It should be at the bottom of the washer reservoir.
Not sure of how the configuration is on the Max, but an old GM car I worked on years ago had a little screen at the bottom of the tank to serve as a crud filter. Turns out the screen had gotten pretty clogged over the years and wasn't allowing enough fluid through.
+1 on the pin idea.
Old Dec 16, 2011 | 10:06 AM
T_Behr904's Avatar
jerrod99_se-l
Aug 27, 2015 08:27 PM
KristyKarina
Aug 23, 2015 09:53 AM
jchronis2552
Aug 13, 2015 07:48 AM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
